Rancho 9000's long enough? #757755
07/25/10 10:41 PM
07/25/10 10:41 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
hey guys,
as some of you may know, i have an issue of wheelhop on my car, and after getting my pinion angle sorted out, i still have some hop (albeit not as bad as before)...id like to step up to the rancho 9000 rears that calvert sells but i have a few questions
first off, i know calvert offers them in stock, lowered, or raised ride heights...which application would be the length im after? currently only have 6cyl leafs with one addded, may go to a super stock spring if the shocks dont work, but i want to make sure i have enough travel...if i go with the stock one, will it be enough even if i go to SS springs, or should i go raised?
also, is calvert the only place who sells these shocks for the mopar application?
thanks for any help in advance...im really hoping these coupled with the calvert 90/10's will work nicely on the car and hopefully help stop the wheelhop (the back shocks anyways)
thanks!
Matthew
Re: Rancho 9000's long enough? [Re: mshred] #757756
07/25/10 10:55 PM
07/25/10 10:55 PM
Indy
cjfordman Offline
cjfordman  Offline
Indy
Upgrade your springs and get the shocks from Calvert and much of your problems should go away.
Re: Rancho 9000's long enough? [Re: mshred] #757757
07/25/10 11:09 PM
07/25/10 11:09 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Why not go with mono springs??
http://chucker54.stores.yahoo.net/rancho.html
http://chucker54.stores.yahoo.net/catrbarsy1.html
phone john and ask they are real good on the phone.
Re: Rancho 9000's long enough? [Re: cjfordman] #757758
07/26/10 04:11 PM
07/26/10 04:11 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
hey guys,
i have talked with john at calvert before, but i just dont feel that caltracs are the ideal thing for my car right now, which sees alot of street miles...if i go with the caltracs im going to go the whole nine yards and get the monos as well, but thats not very ideal for me
back to the original question though, with my 29 inch tire (soon to be 28) should i go the stock height shocks, 1" higher, or 1" lower??? not sure which ones would work best, i dont want a shock that ends up being too short
thanks
matthew
Re: Rancho 9000's long enough? [Re: mshred] #757759
07/26/10 04:15 PM
07/26/10 04:15 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Cant seem to wrap my head around this one. How does tire size affect the shock length unless you are making the shakles longer for clearance.
Dont understand the question.
Kasey
Re: Rancho 9000's long enough? [Re: Moparnut426] #757760
07/26/10 04:18 PM
07/26/10 04:18 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
whats there not to understand? just like the original post stated, im looking to find which shock will be long enough when fully extended on launch with the suspension setup i have (also listed in original post)...i may go to SS springs later as well and i dont want them to be short, and i threw in tire size just in case it was a variable even slightly...dont want to waste my money here
it was all in my first post, so not sure where the confusion is?
Re: Rancho 9000's long enough? [Re: mshred] #757761
07/26/10 04:23 PM
07/26/10 04:23 PM
Moparnut426 Offline
Moparnut426  Offline
Im thinking the 9000 is what everyone runs, and have had good results.
Im running mopar performance HD extra long race shocks cause they were cheap, and if they work good, ill buy the 9000 shocks.
Kasey
Re: Rancho 9000's long enough? [Re: Moparnut426] #757762
07/26/10 04:57 PM
07/26/10 04:57 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Kasey
i know they are a good shock, which is why im asking about them....but what im asking is which specific ones since they are offered stock height, 1" lower and 1" higher...that is the info i am looking for, which one to spring for...nothing else but that
Re: Rancho 9000's long enough? [Re: mshred] #757763
07/26/10 05:09 PM
07/26/10 05:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Where is the body setting in relation to the stock
body height
Re: Rancho 9000's long enough? [Re: MR_P_BODY] #757764
07/26/10 05:36 PM
07/26/10 05:36 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
well i have homemade spring boxes on the car and have the car sitting in the top whole on the box which is 1" higher than the stock location, making the car obviously sit 1" lower....however, im worried that if i go with the 1" lower shock i may not have enough travel...also, if i ever have to put it back to stock ride height for whatever reason, the shocks may not be long enough...kinda why im in a tossup here
looked everywhere and couldnt find specs on the extended and compressed length on these shocks...im still wondering if they will even be long enough at all
Re: Rancho 9000's long enough? [Re: mshred] #757765
07/26/10 05:46 PM
07/26/10 05:46 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
If you think the Rancho's won't be long enough(they should be) then just add some shock extensions.Mr.Gasket makes them.The Rancho website has the compressed and extended length for their shocks.
Nautilus Racing-
Re: Rancho 9000's long enough? [Re: Chris2581] #757766
07/26/10 05:58 PM
07/26/10 05:58 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
If you go to the Rancho site, they have a spec section which shows extended length, and compressed length of all their shocks, just use your measurments and take your pick.
Re: Rancho 9000's long enough? [Re: mshred] #757767
07/26/10 07:06 PM
07/26/10 07:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Since your trying to get multi purpose out of these
I would get under the car and measure it... car on
stands axle up just to lift the body, measure mount
to mount ... thats the curb length... now drop
the axle and measure again... thats your extended
length... ADD 1" for your shock extended length
so you might want to add 3" to YOUR extended length
for SS springs IF it will be ok on the short length
(curb length)
Re: Rancho 9000's long enough? [Re: MR_P_BODY] #757768
07/26/10 09:43 PM
07/26/10 09:43 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
hey guys, perfect! i eventually found the specs at the end of the online catalog...i will measure for shock length tommorow and then go from there...I cant see why none of them wouldnt be long enough, but you never know
for those that have replied, just out of curiosity which ones are you running on your rides?
thanks
matthew
Re: Rancho 9000's long enough? [Re: mshred] #757769
07/26/10 09:55 PM
07/26/10 09:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
thanks
matthew
I run a QA-1 12 way adjustables
Re: Rancho 9000's long enough? [Re: mshred] #757770
07/26/10 10:15 PM
07/26/10 10:15 PM
Ball Ground, Georgia
W
Whips 340 Offline
Whips 340  Offline
W
Matt, I run pro comp 9000's on my duster with super stocks. No problem with the length or clearance.
Re: Rancho 9000's long enough? [Re: Whips 340] #757771
07/26/10 10:38 PM
07/26/10 10:38 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
which part number are you running? the stock ride height ones?
Re: Rancho 9000's long enough? [Re: mshred] #757772
07/26/10 11:17 PM
07/26/10 11:17 PM
W
Whips 340 Offline
Whips 340  Offline
W
Well, I measured my car weighted then unsrung, went to summit and looked in their book until I found what I needed. I added 2 inches to the open length, the compressed length isn't an issue, the ss springs are so stiff, it would be almost impossible to bottom the shocks. as far as which ones I'm using, all thats at the shop, I could look it up for you next time I'm there.
Whip
Re: Rancho 9000's long enough? [Re: mshred] #757773
07/27/10 09:29 PM
07/27/10 09:29 PM
W
Whips 340 Offline
Whips 340  Offline
W
Matt
went by my shop today, got the shock numbers for you. they are pro comp ES 926506. I think that rancho uses the same numbering system.
Whip
Re: Rancho 9000's long enough? [Re: Whips 340] #757774
07/27/10 10:55 PM
07/27/10 10:55 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Hey Whip,
thanks for getting back to me! i checked out the shocks you are running and man they are more than long enough lol...only thing is they arent adjustable, which is what im after in the ranchos...good news is i measured my shocks today...when sitting on its own weight they measured 16.5", but when extended measured 21.5"...So i guess add a few inches to the extended length and that is the length i need?
i had thought that maybe the shocks would be limiting the amount of extension when letting the rear hang to measure, but obviously not since these shocks are supposed to extend to about 24"
