reusing stock leaf springs? #754323
07/21/10 11:14 AM
07/21/10 11:14 AM
n.e. pa.
65rbdodge Offline OP
n.e. pa.
i`ve seen a few mopar street rods using the stock skinny leaf springs(2.25") i`ve decided to use the ones on my 47 desoto. even though they are 53 years old they are probably better made than the ones you can buy today. has anyone ever had any problems with them?
Re: reusing stock leaf springs? [Re: 65rbdodge] #754324
07/21/10 12:22 PM
07/21/10 12:22 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
I had the stock rear springs on my 1936 Humpback panel truck, I put over 120,000 mi on that truck, I had a volare' front end on it and it rode great and I towed my car trailer with it too, it weighed right around 4000 lbs and the stock springs did a fine job.
the only problem I had was finding new shackes for it at that time, I found a new set and everything went together just fine and worked great...
I have been using a lot of mini truck springs on some of vehicles I have built lately. and they work well too. Ron...
Re: reusing stock leaf springs? [Re: 65rbdodge] #754325
07/24/10 03:55 PM
07/24/10 03:55 PM
michigan
black64 Offline
black64  Offline
michigan
You can have your springs re-arched at a front end/frame shop and they will be as good as new. check your local shop to see if they do it.
Re: reusing stock leaf springs? [Re: black64] #754326
07/24/10 04:39 PM
07/24/10 04:39 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
i have the stock width leafs on my 40 dodge,,but they are new from posies rod shop, designed to lower the car 2 inches with out lowering blocks,
and i put in a rear sway bar,,they ride just fine
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: reusing stock leaf springs? [Re: fstfish66] #754327
07/24/10 05:34 PM
07/24/10 05:34 PM
PA
W
Waynes48 Offline
Waynes48  Offline
W
PA
Springs from my 48 Plymouth needed attention. one had a broken short leaf, and they both seemed to sag. Took them to a spring shop in Tamaqua, PA. They replaced the broken leaf,installed new bushings, and made an extra leaf for each spring. Brought up the rear height just right. It's got a nice stance now.
Re: reusing stock leaf springs? [Re: Waynes48] #754328
07/26/10 08:08 PM
07/26/10 08:08 PM
central Kentucky
moprod Offline
moprod  Offline
central Kentucky
actually removed a couple of leafs out of each side of my stock ones. Lowered the car wehere I wanted.
They had like 8-9 leafs each side.
[img] [/img]
Re: reusing stock leaf springs? [Re: moprod] #754329
07/26/10 08:46 PM
07/26/10 08:46 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
Thought about doing this on the 36, need about two inches. How did this affect the ride? Mine is pretty stiff right now.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: reusing stock leaf springs? [Re: 36PLYM] #754330
07/26/10 11:35 PM
07/26/10 11:35 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
I'm making a gasser out my '66 D100. I heard that I can rearch the springs to get extra lift??
Whats the average cost of having this done??
Re: reusing stock leaf springs? [Re: DusterKrazy] #754331
08/04/10 08:49 PM
08/04/10 08:49 PM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
I had the rear springs done on my 1990 pickup with an added leaf. If I remember right the local spring shop charged about $350-$400.
Re: reusing stock leaf springs? [Re: aquamist60] #754332
08/08/10 11:29 PM
08/08/10 11:29 PM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
I built a 1930 plymouth and used the original rear springs. the only problem i had was the brass bushings in the ends where they bolted to the car. the bushing was worn out and i couldnt find anyone making them so i had a machine shop make them for me and they worked good. i added a rear sway bar later and it helped the handeling a lot.
