Re: Broke Another Flex Plate Today !! [Re: supercomp] #750750
07/18/10 09:46 AM
07/18/10 09:46 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
use 2 16 vlt batts.everything will work better and no more kick backs or luggin down.
Re: Broke Another Flex Plate Today !! [Re: sg66mopar] #750751
07/18/10 10:04 AM
07/18/10 10:04 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
With locked out timing MSD says you should phase the distributor especially with a start retard as the jump to other cylinders. adjustable rotor 84211
http://www.msdignition.com/instructions/...s=rotor+phasing
http://www.msdignition.com/instructions/Products/Distributors/84211.pdf?terms=84211
Re: Broke Another Flex Plate Today !! [Re: sg66mopar] #750752
07/18/10 11:44 AM
07/18/10 11:44 AM
Casa Grande,Arizona
DennisJ Offline
super street
DennisJ  Offline
super street
Casa Grande,Arizona
Dick:
Sorry to hear about your many problems this year.
I have always felt that the only time you should lock out your dizzy, is if you are running a crank trigger.
I just spin the engine over and hit the ignition.
Dennis Jokela
PS I see the rain has stopped for a while in Portland.
I started out with nothing,and I still have most of it.
Re: Broke Another Flex Plate Today !! [Re: DennisJ] #750753
07/18/10 12:22 PM
07/18/10 12:22 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mine has never sneezed or had kickback. I crankit for about 10 seconds or so before I ever switch the ignition on.
I have had that issue on my other car though but it is still started with an stock ignition key/switch so the ignition system is on when the starter is cranking.
Re: Broke Another Flex Plate Today !! [Re: Al_Alguire] #750754
07/18/10 01:20 PM
07/18/10 01:20 PM
sg66mopar Offline OP
My whole problem seems to stem from the kickback. As long as I run the mechanical advance in the distributor it doesn't kick back. When I try to lock out the advance I have the problem.
The distributor is new and I've checked rotor phasing. I'm real sure I don't have any spark scatter or cross firing on the plug wires. I only had 30 degrees in the distributor yesterday when it sneezed. The motor was dead cold so no volitile fuel/air in the intake system.
I did my normal procedure for starting when it's cold. About 1/2 pump on the throttle, crank the motor a few revolutions, hit the ignition switch and just a little throttle at the same time. It sneezed as soon as I hit the ignition.
Re: Broke Another Flex Plate Today !! [Re: sg66mopar] #750755
07/18/10 01:46 PM
07/18/10 01:46 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
in my hemi it's more likely to kick back when there's not enough timing.
home of the
Sox and Martin Hemi Duster
