Another ARP torque question #749067
07/15/10 07:56 PM
07/15/10 07:56 PM
Finally a HUSKER again
Moparnut426 Offline OP
Well I bought , and recieved my ARP rocker studs, and they dont come with any specs. 3/8 studs, 3" long, and fine thread nuts. I was going to run them to 30ft lbs with arp lube. Also the brodix heads oil through the same rocker pedistal hole, the bolts I got from B1DARTSPORT are machined in the shank for oil flow to the rocker shafts. I was curious if I could index the stud, and just flatten the side of the stud that shrouds the oil hole, or If I accually have to neck the stud down all the way around the stud. Any ideas? Also there is SOOO much room that it really looks like I dont even have to machine the bolt, but the origional bolts are machined, so Im gonna do the same.
Kasey
Re: Another ARP torque question [Re: Moparnut426] #749068
07/15/10 08:05 PM
07/15/10 08:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Why not check the flow before you cut anything...
stud in the hole then use a priming tool
Re: Another ARP torque question [Re: MR_P_BODY] #749069
07/15/10 08:35 PM
07/15/10 08:35 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Re: Another ARP torque question [Re: b1dartsport] #749070
07/15/10 09:19 PM
07/15/10 09:19 PM
That is what I was accually going to do. But I thought they were like that for a reason, so I just figured Id coppy.
Do you guys think the 30 ft lbs is good??
Oh and Randy, my header tube is in rout, and I plan on dropping the new bullit inn this next week. SUPER excited!!
Im sure Im gonna have to jet up, but I dont know how much.
Kasey
Re: Another ARP torque question [Re: Moparnut426] #749071
07/15/10 09:27 PM
07/15/10 09:27 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
3/8 grade 8 fasteners need a hair more than 30 ft/lbs IMO.
I would torque them to 38-40 ft/lbs. A lbs or two either way should hurt it. But to work properly they need the pre load and stretch some..
That fastener should be very similar to a rod bolt. Both are 3/8 and fine thread also, not that makes a huge diff.
Re: Another ARP torque question [Re: Bob_Coomer] #749072
07/15/10 09:33 PM
07/15/10 09:33 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
do you have a picture and part number for these studs
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Another ARP torque question [Re: Bob_Coomer] #749073
07/15/10 09:39 PM
07/15/10 09:39 PM
These are going through aluminum hold downs, and a harland sharp rocker shaft. I dont want to crush or distort anything, and cause an out of round surface for the rockers.
Kasey
Re: Another ARP torque question [Re: Moparnut426] #749074
07/15/10 09:40 PM
07/15/10 09:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Kasey
I torque 3 things on a engine, mains, rods and the heads
the rest gets the normal twist of the wrist to what
size bolt it is.... look up a torque chart for assorted
size bolts... take a couple pieces of material
and get use to different torques using a ratchet
then check them with a torque wrench... you will
be surprised at what you can pull... on the rocker
shaft hold downs I would give them 35
Re: Another ARP torque question [Re: MR_P_BODY] #749075
07/15/10 09:49 PM
07/15/10 09:49 PM
Kasey
I hear ya Mr P, But I have a Huge investment here that I cant duplicat easily. Ive been working on the side, and saving for 5+ years to get this far. I do the same thing on regular vehicles, and dont torque unless its a high stress area. I think 35 is a good number also.
Kasey
Re: Another ARP torque question [Re: Moparnut426] #749076
07/15/10 09:52 PM
07/15/10 09:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Kasey
You were going to go to 30 with ARP lube and that
would have been over... more like 18 but I would go
oil to 35... look at a ARP chart and look at the differences
from lube to oil... since I tend to have oil around
I tend to use it and go by that torque.... JMO
Re: Another ARP torque question [Re: MR_P_BODY] #749077
07/15/10 09:58 PM
07/15/10 09:58 PM
Im gonna check the ARP chart on line in the AM.
Honestly didnt know they had a chart. I check it out.
Kasey
Re: Another ARP torque question [Re: dusturbd340W5] #749078
07/15/10 10:35 PM
07/15/10 10:35 PM
I can get ya the part number tomarrow, and snap a shot. Ill post them tomarrow nite.
Kasey
Re: Another ARP torque question [Re: Moparnut426] #749079
07/15/10 11:01 PM
07/15/10 11:01 PM
Kissimmee Fl.
Kissimmee Fl.
thanks
Re: Another ARP torque question [Re: dusturbd340W5] #749080
07/16/10 12:47 AM
07/16/10 12:47 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The ARP torque chart is on the box.
Re: Another ARP torque question [Re: Moparnut426] #749081
07/16/10 07:45 AM
07/16/10 07:45 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Kasey
I don't know if you posted it before but what is the new combo? By the way I got that stud set on the engine. You saved me some bucks.
Mark
Re: Another ARP torque question [Re: rowin4] #749082
07/16/10 08:08 AM
07/16/10 08:08 AM
Not on a custom ordered stud set.
Kasey
Re: Another ARP torque question [Re: mac56] #749083
07/16/10 08:13 AM
07/16/10 08:13 AM
Kasey
Mark
72 .030 360 block, Ki 4" crank, Childs track master rods, Diamond pistons, Brodix B1Ba heads, Solid Roller cam, Manton pushrods, Harland sharp rockers, Older eddy performer rpm intake. Its studded, and has a main girdle, Precision oil pump, and topped off with a Quick fuel carb thats a base 750, but I was told flows 850ish. Bought the carb 2nd hand, and it worked GREAT on the old 360.
Re: Another ARP torque question [Re: Moparnut426] #749084
07/16/10 08:41 AM
07/16/10 08:41 AM
Delray beach, Florida
P
Performance Only Offline
P
i'm not a huge fan of those aluminum hold downs. they make it easy to distort the shafts since they clamp only a small area of the shaft.
when using studs on rocker shafts i use blue loctite to secure the stud to the head and green wick-n-lock on the nut. do not overtighten. call Harland Sharp and ask them about it.
the paper work that comes with the rockers should have the recommended torque.
you don't want to torque those down the same as you would for the same fastener in a different application. i would suggest no more than 30 ft. lbs. with 30 wt. oil. it would take 40-45 to stretch the stud and that will distort even a heavy wall shaft like you have. that's the reason i use the loc-tite.
machine shop owner and engine builder
Re: Another ARPA torque question [Re: Moparnut426] #749085
07/16/10 09:04 AM
07/16/10 09:04 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
I would torque them to 38-40 ft/lbs. A lbs or two either way should hurt it. But to work properly they need the Prue load and stretch some..
That fastener should be very similar to a rod bolt. Both are 3/8 and fine thread also, not that makes a huge diff. :two cents:
These are going through aluminum hold downs, and a Harland sharp rocker shaft. I don't want to crush or distort anything, and cause an out of round surface for the rockers.
Kasey
Finally, A mention of distorting or crushing the shaft.
For whats its worth, I have always ran 25 ft-lbs. on shaft studs. 8000 rpm. They lift a little bit, have even bent the shaft between the studs, but never killed a rocker bearing or come loose.
the Harland sharp rockers are particularly sensitive to distortion.
8.30's @3400 lbs
Re: Another ARP torque question [Re: Performance Only] #749086
07/16/10 09:08 AM
07/16/10 09:08 AM
Thanks Dan,
I was gonna call ya on this and ya saved me buggin ya.
Kasey
