Re: Another ARP torque question [Re: dusturbd340W5] #749087
07/16/10 10:07 AM
07/16/10 10:07 AM
Finally a HUSKER again
Moparnut426 Offline OP
The ARP number is AJ3.150, they are 3/8x3.15 long.
Ill post pictures at noon.
Kasey
Re: Another ARP torque question [Re: Moparnut426] #749088
07/16/10 10:16 AM
07/16/10 10:16 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Had a discussion about this with the guy from Comp-u-flow at Carlisle. He says one of the biggest mistakes is overtorquing those bolts. 30 lbs is all they need regardless of the setup. No matter what you're using its still going into the same ALUMINUM hole !!! Also, your turned down bolts were likely for really thick-walled shafts. Harland Sharps don't need turned down bolts or studs. Studs go in finger tight, the nuts get torqued.
Re: Another ARP torque question [Re: Moparnut426] #749089
07/16/10 11:25 AM
07/16/10 11:25 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Kasey
so I take it these are single studs that you order a set of 10
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Another ARP torque question [Re: dusturbd340W5] #749090
07/16/10 11:47 AM
07/16/10 11:47 AM
Yep they will have to sell ya 10 12pt nuts, and 10 hard washers.
Kasey
Re: Another ARP torque question [Re: Moparnut426] #749091
07/16/10 12:02 PM
07/16/10 12:02 PM
Kissimmee Fl.
Kissimmee Fl.
I have the washers and nuts already
Re: Another ARP torque question [Re: dusturbd340W5] #749092
07/16/10 12:09 PM
07/16/10 12:09 PM
Thats cool.
Heres a picture of the studs. Not too great, its on my phone.
Kasey
Re: Another ARP torque question [Re: Moparnut426] #749093
07/16/10 01:39 PM
07/16/10 01:39 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The trick is to call ARP and tell them you want a rocker stud kit for a BB Mopar and they'll put together exactly what you need for about $60.. They know what you need but haven't made it into an actual "kit" as yet. Note: the studs are not all the same length - hence telling them what you're doing!
Re: Another ARP torque question [Re: Stanton] #749094
07/16/10 02:32 PM
07/16/10 02:32 PM
Kissimmee Fl.
Kissimmee Fl.
but i am using these on a SB and all the studs are the same lenght
Re: Another ARP torque question [Re: dusturbd340W5] #749095
07/16/10 05:23 PM
07/16/10 05:23 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Sorry, missed that part!
Re: Another ARP torque question [Re: Performance Only] #749096
07/17/10 08:17 AM
07/17/10 08:17 AM
NC
440Jim Offline
440Jim  Offline
NC
... do not overtighten. call Harland Sharp and ask them about it.
the paper work that comes with the rockers should have the recommended torque.
you don't want to torque those down the same as you would for the same fastener in a different application. i would suggest no more than 30 ft. lbs. with 30 wt. oil. it would take 40-45 to stretch the stud and that will distort even a heavy wall shaft like you have. that's the reason i use the loc-tite.
