ARP2000 rod bolt torque procedure? #748727
07/15/10 08:01 AM
07/15/10 08:01 AM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
Im trying to find out the torque settings/procedure for the ARP rod bolts my buddies bought for his motor. They're ARP2000 bolts in SCAT rods. Theyre 7/16" by 1.8" long.
Re: ARP2000 rod bolt torque procedure? [Re: blown360] #748728
07/15/10 11:13 AM
07/15/10 11:13 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
ARP doesn't give torque specs for their rod bolts anymore and insists the only accurate way to install them is by the "measured stretch" method.
Re: ARP2000 rod bolt torque procedure? [Re: BradH] #748729
07/15/10 12:29 PM
07/15/10 12:29 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Huh ?!?!? I just had a motor done in the last 4 weeks and the ARP2000 rod bolts were "torqued" to spec. I'll see if I can find the sheet.
Re: ARP2000 rod bolt torque procedure? [Re: blown360] #748730
07/15/10 12:37 PM
07/15/10 12:37 PM
NY usa
540challenger Offline
NY usa
http://www.arp-bolts.com/Tech/TechTorque.html
Keep in mind different lube will change the torrgue amount There is another chart some where for that.
Re: ARP2000 rod bolt torque procedure? [Re: 540challenger] #748731
07/15/10 01:07 PM
07/15/10 01:07 PM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
So do I have to use ARP lube then or can I use light oil? What is the stretch method? sorry its just ive never usedthese bolts before! Any info would be a big help!
Re: ARP2000 rod bolt torque procedure? [Re: blown360] #748732
07/15/10 01:18 PM
07/15/10 01:18 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
I just finished a short block with the same rods & bolts. The machinist who supplied the parts told me 65 ft lbs with arp lube or .0054 stretch.
Re: ARP2000 rod bolt torque procedure? [Re: b1dartsport] #748733
07/15/10 01:24 PM
07/15/10 01:24 PM
b1dartsport Offline
b1dartsport  Offline
You need to use a bolt stretch gauge. I looks like this. The one in the picture is made by pro-form
Re: ARP2000 rod bolt torque procedure? [Re: blown360] #748734
07/15/10 03:06 PM
07/15/10 03:06 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Not the same torque for oil and arp lube.
Mains are like 90 ft/lb with arp lube and 120-130 ft/lb with oil
Re: ARP2000 rod bolt torque procedure? [Re: sshemi] #748735
07/15/10 03:08 PM
07/15/10 03:08 PM
sweden
sshemi Offline
sshemi  Offline
sweden
btw get yourself the stretch gauge you will need it more than once.
Re: ARP2000 rod bolt torque procedure? [Re: sshemi] #748736
07/15/10 03:28 PM
07/15/10 03:28 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I know that a strech gauge is the prefered way but there are 1000's of motors built and run succesfully using nothing but a torque wrench.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: ARP2000 rod bolt torque procedure? [Re: dusturbd340W5] #748737
07/15/10 04:59 PM
07/15/10 04:59 PM
sweden
sshemi Offline
sshemi  Offline
sweden
sure there are. i have buildt many of them.
But since i used to work with calibrating torque wrenches i just don trust them any more besides the gauge isnt that expensive just my
Re: ARP2000 rod bolt torque procedure? [Re: sshemi] #748738
07/15/10 05:09 PM
07/15/10 05:09 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
The hughes 426 kit I recently did, all but one bolt was within stretch specs at 63-65 pounds, I kept bumping the TQ a bit at a time because that one bolt would not go past .004 so I used a new bolt on that one.
I also checked them all at 50 pounds to see if they had equal stretch, all did but that one mentioned.
Right or wrong this works for me, I feel without the way to check the stretch that one rod bolt might of caused some issues down the road.
The gauge is semi easy to use, just use it the same way on every bolt.
Re: ARP2000 rod bolt torque procedure? [Re: quick77rt ] #748739
07/15/10 05:33 PM
07/15/10 05:33 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
???? So it looks like you don't trust the stretch method !!
Anyhow, I'm curious as to what the wrench looks like since the gauge would be in the way of a socket.
Re: ARP2000 rod bolt torque procedure? [Re: Stanton] #748740
07/15/10 05:44 PM
07/15/10 05:44 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Maybe I posted wrong but the stretch method is the only way to go imo.
Yes chances are the sheet that says x pounds and so many degrees might be on most the time, however as I mentioned without the gauge I would of had one rod bolt way low on stretch and possibly a big problem from it.
I would not do anything without the stretch gauge.
Re: ARP2000 rod bolt torque procedure? [Re: Stanton] #748741
07/15/10 05:47 PM
07/15/10 05:47 PM
BradH Offline
BradH  Offline
I think you misread things. It looks like the fact that the one bolt wouldn't stretch consistently like the others while attempting to torque them raised a "red flag" that this bolt could have problems. If he'd just kept cranking on the torque wrench until it eventually came up to the target #, he'd have no idea how much the bolt had finally stretched.
Re: ARP2000 rod bolt torque procedure? [Re: BradH] #748742
07/15/10 06:00 PM
07/15/10 06:00 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
A long while back I was looking into the whole stretch vs tq method, found this on a chevy site, dude mixed up on a bolt size vs head bolt size.
How could one not know as posted with this pic, "It wouldnt tighten at 75 pounds"
Re: ARP2000 rod bolt torque procedure? [Re: quick77rt ] #748743
07/15/10 08:05 PM
07/15/10 08:05 PM
NC
440Jim Offline
440Jim  Offline
NC
Where those the ARP 2000 bolts or the regular ARP bolts? What was the stretch spec?
Re: ARP2000 rod bolt torque procedure? [Re: 440Jim] #748744
07/15/10 08:25 PM
07/15/10 08:25 PM
NC
440Jim Offline
440Jim  Offline
NC
FWIW
Re: ARP2000 rod bolt torque procedure? [Re: 440Jim] #748745
07/15/10 08:45 PM
07/15/10 08:45 PM
b1dartsport Offline
b1dartsport  Offline
My Scat rods with the Arp 2000 bolts were all at almost perfect stretch at 65 ft lbs with Arp molly lube.I think 1 of the bolts was off by .0001.-Randy
Re: ARP2000 rod bolt torque procedure? [Re: b1dartsport] #748746
07/15/10 09:15 PM
07/15/10 09:15 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
I dont expect everyone to understand my chicken scratches, these were up to 63 pounds and Im pretty sure I clicked them one time at 65 as mentioned just for kicks. But I rounded down on my 63 lb numbers.
I wont use bolts over or on a freshen up.
The number 2 outter is what I could not get right so I used another new bolt.
Im sure the experts have a different or better (More Correct) way, however ive not had one come apart yet.
This was my bench copy, then I make a puter copy.
Ive read mixed things on the ARP 2000 bolts and the "proper way to install them" from an actual ft pound figure to a certain pound and then so many degrees.
I get them at .0055 and that seems to work for me.
How do others do it?????
