Re: ARP2000 rod bolt torque procedure?
[Re: blown360]
#748734
07/15/10 03:06 PM
07/15/10 03:06 PM
Posts: 2,128 sweden
sshemi
sweden
So do I have to use ARP lube then or can I use light oil? What is the stretch method? sorry its just ive never usedthese bolts before! Any info would be a big help!
Not the same torque for oil and arp lube. Mains are like 90 ft/lb with arp lube and 120-130 ft/lb with oil
[Re: sshemi]
#748736
07/15/10 03:28 PM
07/15/10 03:28 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I know that a strech gauge is the prefered way but there are 1000's of motors built and run succesfully using nothing but a torque wrench.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: sshemi]
#748738
07/15/10 05:09 PM
07/15/10 05:09 PM
quick77rt
Parts Problem
Parts Problem
The hughes 426 kit I recently did, all but one bolt was within stretch specs at 63-65 pounds, I kept bumping the TQ a bit at a time because that one bolt would not go past .004 so I used a new bolt on that one. I also checked them all at 50 pounds to see if they had equal stretch, all did but that one mentioned. Right or wrong this works for me, I feel without the way to check the stretch that one rod bolt might of caused some issues down the road. The gauge is semi easy to use, just use it the same way on every bolt.
[Re: quick77rt ]
#748739
07/15/10 05:33 PM
07/15/10 05:33 PM
Posts: 8,870 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
???? So it looks like you don't trust the stretch method !!
Anyhow, I'm curious as to what the wrench looks like since the gauge would be in the way of a socket.
[Re: Stanton]
#748741
07/15/10 05:47 PM
07/15/10 05:47 PM
BradH
I think you misread things. It looks like the fact that the one bolt wouldn't stretch consistently like the others while attempting to torque them raised a "red flag" that this bolt could have problems. If he'd just kept cranking on the torque wrench until it eventually came up to the target #, he'd have no idea how much the bolt had finally stretched.
[Re: quick77rt ]
#748743
07/15/10 08:05 PM
07/15/10 08:05 PM
Posts: 16,925 NC
440Jim
NC
Where those the ARP 2000 bolts or the regular ARP bolts? What was the stretch spec?
[Re: 440Jim]
#748744
07/15/10 08:25 PM
07/15/10 08:25 PM
Posts: 16,925 NC
440Jim
NC
