Re: Yet another Dana 60 post! Need help w/ ?
[Re: The Duster]
#746992
07/12/10 11:15 PM
07/12/10 11:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
That is pretty narrow... I wouldnt worry about being on the taper other than its more work just got to make them square and parallel... myself, if I had the 9" thats what I would use instead of buying more stuff... Also I would go 4-link now and not even think ladder bars... look at the lengths of the different anti roll bars before you go any farther... try to keep the shocks out as far as possible for better stability...JMO
[Re: The Duster]
#746993
07/13/10 01:46 AM
07/13/10 01:46 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
No way, no how, would I have my suspension brackets welded to cast...but thats just me. Use the 9" you have, or if it must be a Mopar rear, use an 8.75.
Look at it this way...axles are axles, brakes are brakes, spools, gears, etc..they cost the same for either rear. You have the 9". Yes, you will need to buy a decent center and an alum pinion support for the Ford. Both of these will cost you about $500 if you shop around, but you won't have your main suspension components welded to cast.
Monte
[Re: theclutcher]
#747003
07/13/10 03:49 PM
07/13/10 03:49 PM
Monte_Smith
North Alabama
you can get around that width issue. with a removable lower shock mount that spans below the housing. Dont have pics but have done one.
How does that help the area where the suspension brackets attach. I don't have a Dana handy to measure, but with a 20 or 22 frame rail center and a center pinion, I can be pretty sure that one or both brackets would have to be on the webbing and not the tubing.
Never having built a K-car, I can't comment on if the rails need to narrower on the early A body, but I am betting yes. The early A bodies were some of the narrowest cars I have ever worked with.
Monte
[Re: Monte_Smith]
#747004
07/13/10 04:03 PM
07/13/10 04:03 PM
Posts: 3,010 Sac, CA
mopowers
Sac, CA
Early A bodies have just about the same width rear frame rails as later model A's. Also, I believe Dana center sections are about 17.5". Thats going off memory though.
[Re: Flite_727]
#747007
07/13/10 05:31 PM
07/13/10 05:31 PM
Posts: 179 Auburn, Indiana
The Duster
Auburn, Indiana
A friend of mine just offered me a FREE Dana 60, no guts or ends from a 71 Dodge 3/4 ton truck. Is this the way I should go? Moser is who I will probably be using to narrow, and get axles, etc from as I can drive there in about two hours. It looks like most anti roll bars adjust from 16" to 24". At least the ones from A.R.T. do
[Re: The Duster]
#747009
07/13/10 09:45 PM
07/13/10 09:45 PM
Posts: 694 Michigan
Super Scamp
The C/M Frame rails are 21" outside to outside. 4-link brackets are 21" outside to outside. With the Dana 38" flange to flange, It's the most you can get under the car with 33x 16.5x 15 tires rims are 4" b/s. So you have 20" centers and everything lines up. Wheelie bars have room as well.. All parts fore the 4-link are from RJ Race Cars inc. (Quarter-Max) It's very tight with the anti-roll made custom brackets for it to fit centered on the 4-link. Moser spool,axles/bearings and housing ends. I ordered the axles and moser was very helpful with the measurement.
Just One Man's Opinion
Mopar Mafia Racing
