Re: FAST EZ-EFI [Re: Performance Only] #744663
07/11/10 10:05 PM
07/11/10 10:05 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
how quiet (or noisy) are the fuel pumps that come with the kit?
Noisy enough to hear if you have a quiet exhaust. If outside the tank, I recommend insulating the mount.
can an inside the tank pump be used? how about using a stock GM efi pump?
Thats what I went with ( in -tank pump ) so I cant comment on the niose of the external pump.
Re: FAST EZ-EFI [Re: Performance Only] #744664
07/11/10 10:42 PM
07/11/10 10:42 PM
Oakbank, Manitoba, Canada
64 Savoy Offline
64 Savoy  Offline
Any one know if you can mount the "kit" pump in the tank? I have the 307502 kit.
Thanks,
64.............
Re: FAST EZ-EFI [Re: 64 Savoy] #744665
07/12/10 08:09 AM
07/12/10 08:09 AM
PA
68_CONV_300 Offline
68_CONV_300  Offline
PA
Thanks,
64.............
the pump that comes in the kit can only be externally mounted.
I have a full TTI exhaust system on my car and can only hear the rail mount pump that comes in the kit when the car is not running , in contrast the Holley blue pump I used to have on the car I could hear all the time.
The pump that comes in the kit does have an insulating sleeve and rubber coated mounts.
Re: FAST EZ-EFI [Re: 68_CONV_300] #744666
07/12/10 08:19 AM
07/12/10 08:19 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I should be installing mine as a single 4bl TBI next week or the following. I just got the new fuel system with the A1000 pump in the tank running and my trusty 800cfm annular QF carb, and had another big set back. I had another freeze plug that let go! Man, I just can't catch a break. I was told last year when I had to pull the motor for the other one that went, I should have changed all of them while it was out. Ooops.
So when I get my map sensor clip from Rich, a new temp sensor, and fix the stupid freeze plug, it might be ready for a swap. Looks like I can put a new one in without pulling the motor this time, just the header and exhaust. Truck still runs awesome, just leaks water like crazy.
Re: FAST EZ-EFI [Re: Dragula] #744667
07/12/10 12:29 PM
07/12/10 12:29 PM
Dalton, MA
Slipknot440 Offline
Slipknot440  Offline
Dalton, MA
I want one for my hemi so bad. I had the money about lined up for one then lost my job. Hopefully i'll be working by the end of the summer and will be able to buy one during the winter. I'm so sick of carb issues. and if one works i'll buy another for my wife's car
