Re: FAST EZ-EFI
[Re: Performance Only]
#744663
07/11/10 10:05 PM
07/11/10 10:05 PM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
how quiet (or noisy) are the fuel pumps that come with the kit?
Noisy enough to hear if you have a quiet exhaust. If outside the tank, I recommend insulating the mount.
can an inside the tank pump be used? how about using a stock GM efi pump?
Thats what I went with ( in -tank pump ) so I cant comment on the niose of the external pump.
Re: FAST EZ-EFI
#744664
07/11/10 10:42 PM
07/11/10 10:42 PM
Posts: 30 Oakbank, Manitoba, Canada
64 Savoy
Any one know if you can mount the "kit" pump in the tank? I have the 307502 kit.
Thanks,
64.............
Re: FAST EZ-EFI
[Re: 64 Savoy]
#744665
07/12/10 08:09 AM
07/12/10 08:09 AM
Posts: 92 PA
68_CONV_300
PA
Thanks,
64.............
the pump that comes in the kit can only be externally mounted.
I have a full TTI exhaust system on my car and can only hear the rail mount pump that comes in the kit when the car is not running , in contrast the Holley blue pump I used to have on the car I could hear all the time.
The pump that comes in the kit does have an insulating sleeve and rubber coated mounts.
Re: FAST EZ-EFI
[Re: 68_CONV_300]
#744666
07/12/10 08:19 AM
07/12/10 08:19 AM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
I should be installing mine as a single 4bl TBI next week or the following. I just got the new fuel system with the A1000 pump in the tank running and my trusty 800cfm annular QF carb, and had another big set back. I had another freeze plug that let go! Man, I just can't catch a break. I was told last year when I had to pull the motor for the other one that went, I should have changed all of them while it was out. Ooops.
So when I get my map sensor clip from Rich, a new temp sensor, and fix the stupid freeze plug, it might be ready for a swap. Looks like I can put a new one in without pulling the motor this time, just the header and exhaust. Truck still runs awesome, just leaks water like crazy.
