Re: Let's hear some W7,W8,and W9 builds
[Re: 340_Dart]
#1920505
09/27/15 11:33 AM
09/27/15 11:33 AM
Posts: 428 wappinger falls new york
Jimi_Vignogna
300" R3-W8 cfe sheet metal intake Holley 660 cfm carbs,cfe w8 heads 2.15"in 1.6"ex,jesels 1.75r , Weber belt drive , 8.900" deck ht., 2.90" stroke crank, 4.060" bore , 15.0 to 1 comp. Bullet .850" cam. Just shy of 2.4 hp per cube,(715hp) I have run as quick as 9.14@ 147.00 mph 1.23 60' in a 3000# car. I leave the line at 6500, 1-2 shift 9700 2-3 shift 9900, trap is 10,200-10,500 depending on weather .
[Re: 340_Dart]
#1920640
09/27/15 02:47 PM
09/27/15 02:47 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
I read all these and think, "Wow, I wish my small block made that kind of power!" Then I read the shift and peak hp rpms and think, "Wow, I don't want my small block turning any where near that fast!"
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: 69 lawndart]
#1921033
09/28/15 04:41 AM
09/28/15 04:41 AM
Posts: 1,019 Finland
mafo
Finland
Mine is:
R3 4.185 x 3.55 MGP rods 15.0:1 T&D 1.75 rockers LSM cam 280/296 875/840 lift PAC springs CFE W8 CFE tunnelram, davinci dominators 1 7/8 step headers with 3" merge collectors Moroso oil pump, home made pan to fit stock K member and steering
fuel is VP MS109 unleaded
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: 340_Dart]
#2382171
10/04/17 11:58 PM
10/04/17 11:58 PM
Posts: 11,737 Portage,michigan
B3422W5
Portage,michigan
Scottb...... you should post your new build
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
