Electric fuel pump wiring #743192
07/07/10 10:48 PM
07/07/10 10:48 PM
Tucson, AZ
Ramrod39 Offline OP
My New Title
Ramrod39  Offline OP
My New Title
Tucson, AZ
How do you guys wire electric fuel pumps? Back in the day, I would just run a wire from the fuse box to the pump at the rear and ground the pump to the frame. I haven't used an electric pump in many years but am going to now. Is there any real reason to use a system with a relay? If so, how do you wire a relay system and what parts do you use?
Re: Electric fuel pump wiring [Re: Ramrod39] #743193
07/07/10 11:00 PM
07/07/10 11:00 PM
Andrewh Offline
Andrewh  Offline
mostly a load issue on whatever is keying on the pump.
And lets you minimize high amp loads to the old wiring.
Personally I ran a power lead to a fused distribution block to the rear of the car.
Ran the relay from back there, put it all behind the back seat.
Ran the hot and ground through a body plug and ran the wiring to the pump.
I ran a ground distribution block to the back seat as well, all going to the battery through some big bulkhead connectors in the firewall.
Ran a single key on hot to the relay and hid it all along the sides under the trim. Can't see it unless you pull the back seat.
Going to be a pain if I blow a fuse, but I got bigger problems if I eat a 40 amp fuse.
Re: Electric fuel pump wiring [Re: Ramrod39] #743194
07/08/10 08:32 PM
07/08/10 08:32 PM
Tucson, AZ
Ramrod39 Offline OP
My New Title
Ramrod39  Offline OP
My New Title
Tucson, AZ
Anybody else?
Re: Electric fuel pump wiring [Re: Ramrod39] #743195
07/08/10 08:47 PM
07/08/10 08:47 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i run a aeromotive A1000 electric pump with a barry grant 2 speed relay box.
on the low setting i have only 50% of voltage to the pump for low load driving. when i want to step on it i flip the switch to high and get 100% of the voltage to the pump.
has worked trouble free feeding my 572 hemi for 50,000+ miles over the last 10 years.
http://www.jegs.com/i/Barry+Grant/132/180300/10002/-1
Re: Electric fuel pump wiring [Re: Ramrod39] #743196
07/08/10 08:47 PM
07/08/10 08:47 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I ran mine to battery power at the fuse box with an inline fuse and toggle switch under the dash.
Re: Electric fuel pump wiring [Re: ireland383] #743197
07/08/10 09:21 PM
07/08/10 09:21 PM
IN
ahy Offline
ahy  Offline
IN
It depends on the pump and electrical load. If its a smaller carb pump drawing 5-10 amps direct connection to a keyed power source can work. If its a big pump with a lot of load, you need #10 wire through a relay to a good power source like the battery or fender relay. The connection should include a breaker or fuse.
Even with a small pump I think the relay is a good idea. It keeps a continuous added load off the key switch... which it was never designed for in the first place.
I've used a clean chassis ground for (-) with a big pump. No grounding problems.
Re: Electric fuel pump wiring [Re: Ramrod39] #743198
07/08/10 10:41 PM
07/08/10 10:41 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I run mine on a relay with the ground going through an oil pressure switch so it stops if the engine stops running. That way, in an accident, you don't pump a tank of gas all over the pavement and then Just part of my occupational thinking, sorry.
Re: Electric fuel pump wiring [Re: denfireguy] #743199
07/09/10 12:10 AM
07/09/10 12:10 AM
Tucson, AZ
Ramrod39 Offline OP
My New Title
Ramrod39  Offline OP
My New Title
Tucson, AZ
What kind of relay do you use? Anybody got a schematic?
If I go old school and just run a hot wire to the pump, what size wire is needed?
Re: Electric fuel pump wiring [Re: Ramrod39] #743200
07/09/10 12:53 AM
07/09/10 12:53 AM
Shoreline, Washington
72roadrunnergtx Offline
Here's mine, with a oil pressure safety switch and prime button.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Electric fuel pump wiring [Re: Ramrod39] #743201
07/09/10 11:49 AM
07/09/10 11:49 AM
michigan
black64 Offline
black64  Offline
michigan
Besides using a relay, I use a 30 amp circuit breaker to feed the B+ from the battery to the relay (pin 30) instead of a fuse.
