Re: Electric fuel pump wiring
[Re: Ramrod39]
#743195
07/08/10 08:47 PM
07/08/10 08:47 PM
Posts: 4,923 new berlin wisconsin
Mr T2U
i run a aeromotive A1000 electric pump with a barry grant 2 speed relay box. on the low setting i have only 50% of voltage to the pump for low load driving. when i want to step on it i flip the switch to high and get 100% of the voltage to the pump. has worked trouble free feeding my 572 hemi for 50,000+ miles over the last 10 years. http://www.jegs.com/i/Barry+Grant/132/180300/10002/-1
[Re: Ramrod39]
#743198
07/08/10 10:41 PM
07/08/10 10:41 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I run mine on a relay with the ground going through an oil pressure switch so it stops if the engine stops running. That way, in an accident, you don't pump a tank of gas all over the pavement and then Just part of my occupational thinking, sorry.
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
