challenger 6 speed in street rod, shifter driveshaft? #741554
07/06/10 10:35 AM
07/06/10 10:35 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
just got in a 6 speed from a new challenger. it has a funky shifter , just a rod coming out of the back of where the shifter is , it must have some remote shifter set up .
the output shaft just has a flange with 3 bolts and no slip yoke.
how the do you make it work on a street rod project?
is there any way to use a normal shifter and slip yoke?
here is a picture
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: dirt] #741555
07/06/10 11:47 AM
07/06/10 11:47 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
You can just use a driveshaft with a slip built into it (like a 4wd front shaft type setup) Looks to be the same trans (or at least similar) to what's used in the Cadillac CTS-V and Holdens (Pontiac GTO/G8) they use the bolt on flange too..
I "think" I read somewhere or other that you could use a shifter in one of the blank off plates on the top of the trans instead of the rod type setup.
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: OzHemi] #741556
07/06/10 03:47 PM
07/06/10 03:47 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
is there any way to run a normal yoke on the transmission?
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: dirt] #741557
07/06/10 04:08 PM
07/06/10 04:08 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
You try Street & Performance perhaps ?
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: OzHemi] #741558
07/06/10 04:28 PM
07/06/10 04:28 PM
Almont, MI.
gdemon Offline
gdemon  Offline
Almont, MI.
Here is a pic from a 68 cuda conversion. From For A bodys Only.
69 Barracuda 70 Cuda 70 Cuda 70 Cuda Conv. 70 T/A Challenger 70 Sport Fury GT 71 Demon 5.7 Hemi 72 Demon
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: gdemon] #741559
07/06/10 04:30 PM
07/06/10 04:30 PM
Almont, MI.
gdemon Offline
gdemon  Offline
Almont, MI.
another
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: gdemon] #741560
07/06/10 06:49 PM
07/06/10 06:49 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
thanks, that looks like it would work. is it a 4 wheel drive driveshaft?
i was looking on that forum but didnt find that thread. how do you find it?
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: dirt] #741561
07/06/10 07:14 PM
07/06/10 07:14 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
great post. I was looking to buy a 6 speed for mine. can we use a different bellhousing? i think i will need to have starter on drivers side to cleat TTI headers. What is the designation of tranny. T-56 or tko ###? thanks
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: hemibeep] #741562
07/06/10 08:07 PM
07/06/10 08:07 PM
Chicagoland
chargerron69 Offline
Chicagoland
looks like a regular t56. a 03-04 cobra shifter should work, thats what i put on my viper t56
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: chargerron69] #741563
07/06/10 08:31 PM
07/06/10 08:31 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
its the model after the t56, its a 6060. supposed to be a better version of the t56. the aftermarket ones have a different tail shaft and call it a T56 magnum.
It does look like a regular t56 shifter would bolt on but i havent taken it apart to see yet. and the only t56 shifter i have to try is in my daytona.
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: dirt] #741564
07/06/10 08:40 PM
07/06/10 08:40 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That's another one of those parts engineered by Merciless Bends and dropped on Chrysler.
Meet the Mercedes flex disc.
Perhaps you can nab a drive shaft and swap to a rear yoke after you cut it down.
- Stu Harmon
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: feets] #741565
07/15/10 08:46 AM
07/15/10 08:46 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I tried a shifter from a 98 viper T56 in the challenger trans and it would have worked but the bolt holes were off about 1 /8" length ways. i cant believe that .i set it in and could shift with it but the holes were just off. why would they do that?
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: dirt] #741566
07/15/10 10:44 AM
07/15/10 10:44 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Just elongate the holes
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: dirt] #741567
07/15/10 10:45 AM
07/15/10 10:45 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Wonder if an F body one would be any closer..I can take a pic of mine for you if it would help at all..
Found a pic from a little while ago on my project that shows it..looks like the shifter plate bolts are abit further apart than on yours. Maybe see what the Ford ones look like too?
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: gdemon] #741568
08/06/10 10:54 AM
08/06/10 10:54 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I cant find anyone who can get the piece to attach to the flange on the ind of the transmission. everyone is telling me to get the original driveshaft and try to modify it.
does anyone know if there is something available to bolt up th the flange or will i have to track down a factory driveshaft?
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: dirt] #741569
08/06/10 11:37 AM
08/06/10 11:37 AM
Byesville, Ohio
Tomsecks Offline
Tomsecks  Offline
Byesville, Ohio
Can you measure the 4-bolt plate on there? Looks like the same pattern as what comes on the TKO, could probably pop the tail off and add the internal part on to the shifter rail, and you'd be in business.
Or you could nab the stock shifter too and modify it.
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: dirt] #741570
08/06/10 12:37 PM
08/06/10 12:37 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
It looks the same (or very similar) to a Cadillac CTS-V version, maybe grab a used driveshaft front half out of one of those for the flange setup?
If not, in doing a very fast search around, looks like changing the extension housing and output shaft to F body is what some of the GM people are doing to use that trans in 'normal' stuff
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: gdemon] #741571
08/11/10 12:57 PM
08/11/10 12:57 PM
W. Bloomfield, MI
71340vert Offline
71340vert  Offline
W. Bloomfield, MI
My NAG 1 transmision from an 09 challenger has the same end on it. I went to a place near me called shaft masters. The told me no problem. They would make me a custom aluminun drive shaft that was splined and slip in and out of it self a little. They would make a cnc aluminum adapter to fit on the end of the trans with a yolk for a ubolt to bolt up to the drive shaft. I asked about modifying the driveshaft that was from this trans and he said his would be much stronger. Price was about $450. I have not had it made yet since I dont have the measurement to give him yet
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: 71340vert] #741572
08/11/10 01:50 PM
08/11/10 01:50 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I wish i could find a shop to do that to mine. i ordered a challenger driveshaft yeasterday so i could try and make one from it to work.
Can you get the phone number to the shop that you were talking to about making a driveshaft? that sounds like the best way to go.
I did talk to a place about changing the tail shaft but they never got back to me on it.
i got the challenger shifter and figure i can make it work if i shorten up the rods a little it will end up in the right location for my car.
i did try the viper shifter from my other viper T56 and it would fit up and shift but i couldnt get the 2 front bolts in the shifter they were about 1/8" off
Re: challenger 6 speed in street rod, shifter driveshaft? [Re: dirt] #741573
08/11/10 02:36 PM
08/11/10 02:36 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
There is an awesome driveshaft shop out here too, and imagine they could do a similar one (just had a normal one built about a week and a half ago actually)
Might be worth a call at least.. Powertrain Industries. 714-893-4585
