Re: What turbo's for a 440
[Re: Boise Chall]
#741370
07/06/10 06:37 PM
07/06/10 06:37 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
Are you running a single Garret or twins? I plan to run twins. What did the Garrett TV8101 come on Powerstrokes?
It's a 85mm single. I'm not sure what they came on. You can search the net for more info on them. I paid around 400 for mine from someone, rebuilt from Majestic turbo with a polished compressor housing.
[Re: blowndart]
#741371
07/07/10 10:41 AM
07/07/10 10:41 AM
Posts: 2,260 IL
furious70
IL
big dump trucks and the like. The TV series is older tech, but a good affordable option. I've been trying to score one myself for a reasonable price in decent condition.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: blowndart]
#741372
07/07/10 11:29 AM
07/07/10 11:29 AM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Majestic Turbo in Dallas does all my turbo stuff. Mike has always been good to me. www.dallasturbo.com
[Re: CW25]
#741374
07/09/10 02:31 PM
07/09/10 02:31 PM
Posts: 846 Illinois
moparmattkos
mopar addict
mopar addict
Illinois
There is a great deal on here right now on a 88mm for sale.The 88 will give you the power you want plus give you alot of room to grow power if you want to later without having to upgrade the turbo. If i didnt already have the 106mm i would have jumped on it for the price. ![](/ubbthreads/images/graemlins/thumbs.gif) Posted by the member --- Heads UP 88mm garrett/ air reasearch turbo ran 5.70 @ 126 in my 3300lb leaf spring car on its 5th pass, A/A cooler, blow-thru carb on race gas w/28x10 and 15 lbs of boost. It has a 3.5 in outlet on cold side and 5in v-band clamp for exhaust. I have a 1.39 ar housing that has 10 runs since new and what looks to ge a .96 or 1.15 I'm not sure what it is that came with it included. The only reason for selling is I have just went to a larger turbo. 850$ thanks you can pm me here, Will ship
[Re: CW25]
#741378
09/30/10 05:46 PM
09/30/10 05:46 PM
Posts: 121 mid-mich
turboplymouth
mid-mich
I'm kinda partial to my combination. S400-75 is cheap. 80 or 88 might be better suited for all out power, but this working well. turbo forums
'72 Scamp, 3500#, 440, S400, blowthrough, meth. inj.
9.78 @ 139 so far at 12 psi, 11.00 @ 131 on real street tires.
[Re: Quicksilver440]
#741381
10/03/10 08:15 PM
10/03/10 08:15 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
turbo forums
Are you just running one of those? or two?
He's running one.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
