What turbo's for a 440 #741366
07/06/10 02:38 AM
07/06/10 02:38 AM
Boise Idaho
Boise Chall Offline OP
Boise Idaho
What Turbo's would work best for a fairly mild fuel injected twin turbo 440 in a 73 Roadrunner street car? I'm looking to make 600-800 rwhp. I prefer cheap or junkyard as this is my first turbo experience. I am planning on making my own log style ex manifold and putting one turbo in the area the battery was in and the other one in about the same area on the passenger side in the burp tank area. I am not planning to start this project until winter but would like to start looking for the turbo's/parts now so I am ready when the fun starts
Re: What turbo's for a 440 [Re: Boise Chall] #741367
07/06/10 05:32 AM
07/06/10 05:32 AM
Fredericktown, PA 15333
maundmotorworks Offline
Stealth poster
Stealth poster
I used to have a twin turbo setup for a 440 that used Garrett T04 turbos. Those are pretty easy to find.
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: What turbo's for a 440 [Re: maundmotorworks] #741368
07/06/10 09:26 AM
07/06/10 09:26 AM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
Garrett TV8101 would work. That's what I'm running on my 440. Relatively cheap (around $300-$400) and will easily give you 800 HP.
Re: What turbo's for a 440 [Re: blowndart] #741369
07/06/10 05:20 PM
07/06/10 05:20 PM
Boise Idaho
Boise Idaho
Are you running a single Garret or twins? I plan to run twins. What did the Garrett TV8101 come on Powerstrokes?
Re: What turbo's for a 440 [Re: Boise Chall] #741370
07/06/10 06:37 PM
07/06/10 06:37 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
It's a 85mm single. I'm not sure what they came on. You can search the net for more info on them. I paid around 400 for mine from someone, rebuilt from Majestic turbo with a polished compressor housing.
Re: What turbo's for a 440 [Re: blowndart] #741371
07/07/10 10:41 AM
07/07/10 10:41 AM
IL
furious70 Offline
furious70  Offline
IL
big dump trucks and the like. The TV series is older tech, but a good affordable option. I've been trying to score one myself for a reasonable price in decent condition.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: What turbo's for a 440 [Re: blowndart] #741372
07/07/10 11:29 AM
07/07/10 11:29 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Majestic Turbo in Dallas does all my turbo stuff. Mike has always been good to me.
www.dallasturbo.com
- Stu Harmon
Re: What turbo's for a 440 [Re: feets] #741373
07/09/10 12:04 AM
07/09/10 12:04 AM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
A S400 would work faily well depending on desired boost.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: What turbo's for a 440 [Re: CW25] #741374
07/09/10 02:31 PM
07/09/10 02:31 PM
Illinois
moparmattkos Offline
mopar addict
mopar addict
Illinois
There is a great deal on here right now on a 88mm for sale.The 88 will give you the power you want plus give you alot of room to grow power if you want to later without having to upgrade the turbo. If i didnt already have the 106mm i would have jumped on it for the price.
Posted by the member --- Heads UP
88mm garrett/ air reasearch turbo ran 5.70 @ 126 in my 3300lb leaf spring car on its 5th pass, A/A cooler, blow-thru carb on race gas w/28x10 and 15 lbs of boost. It has a 3.5 in outlet on cold side and 5in v-band clamp for exhaust. I have a 1.39 ar housing that has 10 runs since new and what looks to ge a .96 or 1.15 I'm not sure what it is that came with it included. The only reason for selling is I have just went to a larger turbo. 850$ thanks you can pm me here, Will ship
www.sikosracing.net Heads up Drag racing
Re: What turbo's for a 440 [Re: moparmattkos] #741375
07/16/10 01:03 PM
07/16/10 01:03 PM
USA
BB Dart 69 Offline
BB Dart 69  Offline
USA
can you tell me where you found this post at
Re: What turbo's for a 440 [Re: BB Dart 69] #741376
09/28/10 06:30 PM
09/28/10 06:30 PM
Visalia Ca
P
prostreet68 Offline
prostreet68  Offline
P
Visalia Ca
I was told a pair of S475 turbos would work. This turbo is right off the shelf for the Detroit 60 diesel engines with no fancy modifications.
Rick
Re: What turbo's for a 440 [Re: prostreet68] #741377
09/29/10 09:27 PM
09/29/10 09:27 PM
CW25 Offline
CW25  Offline
Those are a T6 framed turbo you better have alout of engine to turn the exhaust side of 2 of those.
Re: What turbo's for a 440 [Re: CW25] #741378
09/30/10 05:46 PM
09/30/10 05:46 PM
mid-mich
turboplymouth Offline
mid-mich
I'm kinda partial to my combination. S400-75 is cheap. 80 or 88 might be better suited for all out power, but this working well.
turbo forums
'72 Scamp, 3500#, 440, S400, blowthrough, meth. inj. 9.78 @ 139 so far at 12 psi, 11.00 @ 131 on real street tires.
Re: What turbo's for a 440 [Re: turboplymouth] #741379
09/30/10 06:46 PM
09/30/10 06:46 PM
Calif U.S.A.
moparray Offline
moparray  Offline
Calif U.S.A.
Hey turboplymouth can we see some pics?
Re: What turbo's for a 440 [Re: turboplymouth] #741380
10/03/10 12:32 PM
10/03/10 12:32 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
turbo forums
Are you just running one of those? or two?
Re: What turbo's for a 440 [Re: Quicksilver440] #741381
10/03/10 08:15 PM
10/03/10 08:15 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
turbo forums
He's running one.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: What turbo's for a 440 [Re: topfueldart] #741382
10/08/10 11:39 PM
10/08/10 11:39 PM
Amherst,NY
challengermike Offline
Amherst,NY
So would that same size turbo also be suited for a 440 stroked to 499?
Re: What turbo's for a 440 [Re: moparray] #741383
10/11/10 07:30 PM
10/11/10 07:30 PM
mid-mich
mid-mich
Check the turbo forums post.
Re: What turbo's for a 440 [Re: challengermike] #741384
10/11/10 07:31 PM
10/11/10 07:31 PM
mid-mich
mid-mich
No, It's borderline for a 440 street motor. You would want the 88 for a 499"
Re: What turbo's for a 440 [Re: turboplymouth] #741385
10/11/10 07:47 PM
10/11/10 07:47 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
I would like to see some too.
I went and checked but did not see any pics
I would like to go twin turbos too but your set up sounds interesting
