360 magnum/904 balance list #740363
07/04/10 06:15 PM
07/04/10 06:15 PM
Colorado
swingers_rock Offline OP
super gas
super gas
Colorado
Hi guys im getting ready to mate my 360 magnum to my 904 and was wondering if these parts will get me up and running.
flexplate
harmonic balancer
torque converter weights
Re: 360 magnum/904 balance list [Re: swingers_rock] #740364
07/04/10 08:39 PM
07/04/10 08:39 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the flexplate says it is for an externally balanced 360 1993-1999...You dont need the weights on the converter..
I believe B&M quit making the 10241,,,,,
B&M 10241 Flexplate.
Fits 1993-1999, Chrysler externally balanced 360 with A-904.
(10" bolt circle)
SFI approved flexplates from B & M are legal for use in all classes of NHRA and IHRA drag racing. They are also ideal for high performance street use or any application that may see higher than 6,000 rpm. They come with the SFI certification sticker and will not need recertification for three years
Tony
70 AARCuda Vitamin C
Re: 360 magnum/904 balance list [Re: 70AARcuda] #740365
07/04/10 10:37 PM
07/04/10 10:37 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
stock 5.9 harmonic balancer is what you need.
Ideally, the correct B&M flex plate will not require any converter weights (neutral balance). Don't know if B&M still makes the part you need.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 360 magnum/904 balance list [Re: GO_Fish] #740366
07/04/10 10:56 PM
07/04/10 10:56 PM
Colorado
super gas
super gas
Colorado
I believe that B&M flexplate is on back stocked on that internet site, so I will probably get that and the stock 5.9 balancer and I should be set.
Re: 360 magnum/904 balance list [Re: swingers_rock] #740367
07/05/10 12:36 AM
07/05/10 12:36 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Flexplate is "discontinued", i called B&M on this, i asked why, they said its because most are useing 727s anymore, sales were way down, so its a gone-rrrr.
All he needs if he's going to use a stock factory shortblock is a flexplate from a later model 360 magnum that has the weights on it, then he can run a "N" balanced converter, then just run a factory HB.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 360 magnum/904 balance list [Re: joedust451] #740368
07/05/10 01:35 AM
07/05/10 01:35 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the 727 flexplate comes with 3 different bolt patterns...
11 1/8 and 10 inch...plus different bolt hole sizes...i dont see why it would not work.
check the bolt pattern on your converter...see if it is either of those two.
Tony
Re: 360 magnum/904 balance list [Re: 70AARcuda] #740369
07/05/10 09:39 AM
07/05/10 09:39 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
I'm pretty sure the larger dia of the 727 flexplate will hit the starter in the drive area.
Even using the B&M 360/904 flexplate, I've had to trim the nose on some mini-starters to clear. I've also had to trim the block in the pan rail area to put a 904 behind a 360 Mag block.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: 360 magnum/904 balance list [Re: 70AARcuda] #740370
07/05/10 10:45 AM
07/05/10 10:45 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I'll post some pics in a few minutes.
Re: 360 magnum/904 balance list [Re: Evil Spirit] #740371
07/05/10 02:29 PM
07/05/10 02:29 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
B&M 10242 (5.9 magnum) Flexplate shown with 904, 727 and magnum flexplates. I see no reason why the 10242 would not work with the 904 even though it is listed for 727 applications.
NOTE- Not all magnum flexplates are the same! Early units had the 5.9 weight attached to the converter, later ones were attached to the flexplate.
Re: 360 magnum/904 balance list [Re: gdonovan] #740372
07/05/10 02:30 PM
07/05/10 02:30 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
B&M flexplate with 904 overlaid.
Re: 360 magnum/904 balance list [Re: gdonovan] #740373
07/05/10 02:31 PM
07/05/10 02:31 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
B&M flexplate with 727 overlaid.
Re: 360 magnum/904 balance list [Re: gdonovan] #740374
07/05/10 05:01 PM
07/05/10 05:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The 904 usesa 122 tooth ring gear, the 727 uses a 130 tooth ring gear. The smaller diameter of the 904 ring gear prevents using a 727 flexplate.
Re: 360 magnum/904 balance list [Re: John_Kunkel] #740375
07/05/10 05:09 PM
07/05/10 05:09 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Interesting, I'll have to do a test fit with the 42RH I have here.
This could be a problem for me as I was doing a motor swap next month.
Question- Does anyone make interal balanced flexplates for the 904 application with a six bolt crank? I'm amazed B&M does not have one listed!
I'd simply get it rebalanced for a magnum 5.9.
Re: 360 magnum/904 balance list [Re: gdonovan] #740376
07/05/10 05:40 PM
07/05/10 05:40 PM
Colorado
super gas
super gas
Colorado
Thanks for the pictures gdonovan. Would have have a weighted stock 5.9 flexplate for sale?
Re: 360 magnum/904 balance list [Re: swingers_rock] #740377
07/05/10 06:33 PM
07/05/10 06:33 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I do not.
Re: 360 magnum/904 balance list [Re: gdonovan] #740378
07/05/10 07:14 PM
07/05/10 07:14 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Took a picture of the B&M flexplate over a 42RH (904) converter.
My Mark One eyeball tells me there is about .030-.045 between the outside of the flexplate and the lowest valley of the ring gear.
Guess the only way to find out if it will work or not is to mock everything up.
Re: 360 magnum/904 balance list [Re: swingers_rock] #740379
07/06/10 07:41 AM
07/06/10 07:41 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
When I did my stroker magnum build I used a B&M flexplate to my 904 trans. I will look today to see if I stil have my old flexplate and if its weighted.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: 360 magnum/904 balance list [Re: joedust451] #740380
07/06/10 08:03 AM
07/06/10 08:03 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
will it work? all 360 mags came with a 727 based tranny (some vans got a 727 (37RH), most came with a 46RH/RE (A518)
2017 Grand Cherokee Overland
Re: 360 magnum/904 balance list [Re: joedust451] #740381
07/06/10 03:24 PM
07/06/10 03:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
When the factory changed to a weighted flexplate they also changed to a symmetric 90° converter bolt pattern, the 727 and 904 converters have one drive lug offset so the newer flexplate won't work on the 904 without elongating one hole.
Re: 360 magnum/904 balance list [Re: John_Kunkel] #740382
07/06/10 05:08 PM
07/06/10 05:08 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
With the weighted flexplate and a symmetric pattern, what stops you from mounting it in the wrong orientation??
