Safety Neutral Switch???? #739013
07/02/10 09:08 PM
07/02/10 09:08 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
70 RR 727 My back up lites don't work but I can jump the plug at the tranny and they work. Does this make my switch bad? It is a new one but I guess it could be. What do you think? Thanks Ronnie
Re: Safety Neutral Switch???? [Re: okie] #739014
07/02/10 09:35 PM
07/02/10 09:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Are you sure it's going all the way into REVERSE enough to turn on the lights? Edited because of brain burp.I was refering to it being out of adjustment.
Re: Safety Neutral Switch???? [Re: stumpy] #739015
07/02/10 09:38 PM
07/02/10 09:38 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Are you sure it's going all the way into park enough to turn on the lights?
back up lights in Park??????
Re: Safety Neutral Switch???? [Re: MoparforLife] #739016
07/02/10 10:07 PM
07/02/10 10:07 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It's more likely that the shifter is out of adjustment, but the switch could also be bad.
Re: Safety Neutral Switch???? [Re: Jim_Lusk] #739017
07/03/10 06:32 AM
07/03/10 06:32 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
I thought that if it was set where it would start in park it was close. I moved it just a little to get it to start. All new bushings on the linkages. So what do I need to do? Do I need to mess with it again? Ronnie
Re: Safety Neutral Switch???? [Re: okie] #739018
07/03/10 06:49 AM
07/03/10 06:49 AM
NH
72challorange Offline
He's Game
He's Game
NH
Could be the rooster comb in the trans(it's plastic), they can fail. Test your switch with a multimeter in reverse.
Tom
Re: Safety Neutral Switch???? [Re: 72challorange] #739019
07/03/10 06:51 AM
07/03/10 06:51 AM
NH
He's Game
He's Game
NH
I tried to search here but this was faster.
Tom
http://www.cuda-challenger.com/cc/index.php?topic=61851.0
Re: Safety Neutral Switch???? [Re: 72challorange] #739020
07/03/10 11:35 AM
07/03/10 11:35 AM
5thAve Offline
5thAve  Offline
I was just going to say- if you think it's the switch pull it out and stick a volt meter on it and see what it does. But that last link seems to say how to check it anyway. The last one I had go bad the spring was no good in it. Or just buy a new one and try changing it. They don't cost much and any parts store should have it.
Re: Safety Neutral Switch???? [Re: 5thAve] #739021
07/03/10 02:34 PM
07/03/10 02:34 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
I think I'm just going to trade it for another new one and try that. I've got several different new switches that have been bad. You know they are made in China are Mexico now. Ronnie
Re: Safety Neutral Switch???? [Re: okie] #739022
07/03/10 03:04 PM
07/03/10 03:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Some of the replacement switches now available are reportedly too long and don't allow the center plunger to extend far enough to trigger the BU lights.
Re: Safety Neutral Switch???? [Re: John_Kunkel] #739023
07/03/10 05:12 PM
07/03/10 05:12 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
How would I know if it was too long are not? Ronnie
Re: Safety Neutral Switch???? [Re: okie] #739024
07/03/10 05:43 PM
07/03/10 05:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If it works on the bench but not in the transmission the pin is too long. Some people claim to have used washers to space the switch out of the case but with the cupped gasket......?
Re: Safety Neutral Switch???? [Re: John_Kunkel] #739025
07/04/10 01:44 AM
07/04/10 01:44 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
A lot of the connectors plactic is really hard now and do not make good connection on the trans switch, or fall off completely.
Re: Safety Neutral Switch???? [Re: sthemi] #739026
07/04/10 07:56 AM
07/04/10 07:56 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
It is plugging on the switch good and tight. I took a wire and jumped the 2 outside prongs and the lites came on. I'll just have to go to checking stuff when I go back to the shop. Ronnie
Re: Safety Neutral Switch???? [Re: okie] #739027
07/04/10 02:58 PM
07/04/10 02:58 PM
5thAve Offline
5thAve  Offline
I haven't gotten a new one that wasn't bad yet. They are pretty simple how they work. But I didn't know they aren't even making them right. That sucks.
