MSD Dist. RB to B conversion #738491
07/02/10 09:29 AM
07/02/10 09:29 AM
texas
yellowsubNSS Offline OP
texas
Im trying to stop the bleeding from my wallet on the new 499 build and i'm down to changing out my tall deck Distributor to a low deck. I got this bright thought in my head to call MSD and see if I could just change out the shaft to turn it into the low deck height dist. He quickly blurted out a part number saying this is what I need. only $ 37.00 + freight.
Any of u guys ever perform this surgery on yours?
And to think that they use to sell a spacer that cost double that amount to make them interchange.
Texas Outsiders Nostalgia Super Stocks
Re: MSD Dist. RB to B conversion [Re: yellowsubNSS] #738492
07/02/10 09:39 AM
07/02/10 09:39 AM
Col. Ohio
The Avg. Valiant Offline
Col. Ohio
I wasnt able to get either part from Summit or Jegs. I waited 3 months then just ordered the right dist.
Post deleted by Defbob [Re: The Avg. Valiant] #738493
07/02/10 09:58 AM
07/02/10 09:58 AM
Re: MSD Dist. RB to B conversion #738494
07/02/10 10:21 AM
07/02/10 10:21 AM
texas
texas
LOL... I guess I know myself to well. Will prob. have another tall deck in it in the near future.
It was on my mind though.
Re: MSD Dist. RB to B conversion [Re: yellowsubNSS] #738495
07/02/10 10:39 AM
07/02/10 10:39 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
If what you are asking is it hard to change the shaft the answer is no. It only takes a few minutes. It is almost the same process as locking out the distributor. I made a spacer for mine from specs someone here posted but I'm not happy with the engagement to the pump drive. I may just cut the shaft as Fred suggested.
Re: MSD Dist. RB to B conversion [Re: yellowsubNSS] #738496
07/02/10 11:35 AM
07/02/10 11:35 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Mopar sells an aluminum spacer to slip onto the shaft of a RB distributor to use it in a low deck block. Includes a longer bolt and hold down bracket. About $65 from Chicago Connection. MP number is Mopar Performance P3690275
Scott
Re: MSD Dist. RB to B conversion [Re: ProStDodge] #738497
07/02/10 02:14 PM
07/02/10 02:14 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Scott
I don't believe this spacer works with msd distributor. If shaft is only 37 bucks would'nt make sense.
Re: MSD Dist. RB to B conversion [Re: mac56] #738498
07/02/10 02:51 PM
07/02/10 02:51 PM
NC
440Jim Offline
440Jim  Offline
NC
The MSD distributor needs a much bigger hole in the adapter. The MP part has a hole about 1-1/8" and the MSD distributor is around 1.5" dia.
