Anyone know the specs on the old trw 2293 piston? #737697
06/30/10 09:19 PM
06/30/10 09:19 PM
Toronto Ontario, Can
Glen440 Offline OP
Glen440  Offline OP
I have a 383 with the .030 trw 2293 domes. I'm curious what the dome cc is.
This engine was built way back in 1980, heads are 906's with double springs and aluminum retainers. Some weird rod bolts with a locking style nut. It has main studs and head studs with a 7 quart pan and HV oil pump. There is no cam in it so no idea what was in it
87 dakota 6.1 hemi
Re: Anyone know the specs on the old trw 2293 piston? [Re: Glen440] #737698
06/30/10 09:23 PM
06/30/10 09:23 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I "think" it's 12cc's IIRC.I have the same slugs in my old 383.It's been a long time since we bought those pistons.
Nautilus Racing-
Re: Anyone know the specs on the old trw 2293 piston? [Re: Chris2581] #737699
06/30/10 09:31 PM
06/30/10 09:31 PM
Glen440 Offline OP
Glen440  Offline OP
I have been coming up with all different answers searching the web, people saying they are 11.5-1 with 88cc heads which would make the dome huge.
87 dakota 6.1 hemi
Re: Anyone know the specs on the old trw 2293 piston? [Re: Glen440] #737700
07/01/10 12:28 AM
07/01/10 12:28 AM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
I have those pisrtons in my 383... The spec from TRW is 22cc.
Hope this helps!
Paul
'69 Super Bee 383 EFI Turbo
Re: Anyone know the specs on the old trw 2293 piston? [Re: Black_Bee] #737701
07/01/10 09:19 AM
07/01/10 09:19 AM
Glen440 Offline OP
Glen440  Offline OP
Maybe a better question is how much cylinder pressure do people have with these?
I'm trying to decide on what head gasket to use, there is a huge difference between 12 and 22 cc.
87 dakota 6.1 hemi
Re: Anyone know the specs on the old trw 2293 piston? [Re: Glen440] #737702
07/02/10 11:33 AM
07/02/10 11:33 AM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
Its been years since I built my engine, but I'm pretty sure I ended up with 11.3:1 with the pistons .005 in the hole and 88cc edelbrock heads.
I have a small solid cam (232/242) in the engine and it was pushing 195ish psi if I remember correct.
Hope this helps.
Paul
Re: Anyone know the specs on the old trw 2293 piston? [Re: Glen440] #737703
07/02/10 02:24 PM
07/02/10 02:24 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
What gas are you trying to use?
Mine; .045 in the hole, 1009 gasket, w/82 cc 906s, wouldn't come close to running ok on pump gas even with the timing turned way down. I run C12 , and now have 75cc aluminum -1's on it. Don't know for sure what the compression is, but it ran 130 mph in a 2900# + 67 cuda.
Rem
Re: Anyone know the specs on the old trw 2293 piston? [Re: Black_Bee] #737704
07/02/10 03:56 PM
07/02/10 03:56 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
That's right from the book, 22.3 cc effective dome for the .030" oversized piston, a little less for the .060" over.
Re: Anyone know the specs on the old trw 2293 piston? [Re: Black_Bee] #737705
07/03/10 05:41 PM
07/03/10 05:41 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
Hope this helps.
My engine runs fine on 92... When I ran iron 906s it pinged all the time.
Paul
Re: Anyone know the specs on the old trw 2293 piston? [Re: Black_Bee] #737706
07/03/10 06:07 PM
07/03/10 06:07 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
Let me add ....
I am going to use these pistons in a decked block with the 019 gasket and stock-type 452 heads IN a boat ....so it will not be "loaded" as tight as in a automotive application.
I think I will be able to get-away with pump-premium .. 93 octane.
Re: Anyone know the specs on the old trw 2293 piston? [Re: dOc !] #737707
07/04/10 05:09 PM
07/04/10 05:09 PM
Glen440 Offline OP
Glen440  Offline OP
Thanks everyone
I'm trying to figure out what exactly I'm gonna do with this engine. I have a 440 block getting machined at the moment. My duster needs an engine with the 511 being pretty smashed up. Gonna go back to having fun before I revisit the B1 engine.
If the 383 would run high 10's in a light A body back half car I would put it in it.
87 dakota 6.1 hemi
Re: Anyone know the specs on the old trw 2293 piston? [Re: Glen440] #737708
07/04/10 05:42 PM
07/04/10 05:42 PM
Sidney Ohio
9SecRoadRunner Offline
Sidney Ohio
my brothers duster has those pistons +.060, 590 MP cam, ported 452 heads, all steel car , working windows, factory wiring , lights and heater box etc still in car...runs 10.70's @ 125
You Thinking It's So Doesn't Make It a Fact
Re: Anyone know the specs on the old trw 2293 piston? [Re: 9SecRoadRunner] #737709
07/04/10 08:29 PM
07/04/10 08:29 PM
Florida STAYcation
Florida STAYcation
Did you have to fly-cut the pistons with the 590 ? ... if so - how much? .....and where did those pistons come-up .. on the deck?
Re: Anyone know the specs on the old trw 2293 piston? [Re: dOc !] #737710
07/05/10 11:44 AM
07/05/10 11:44 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I didn't on mine. .585 comp,275 at .050, amd 1.6 intakes, but they are tight. Around .070 on the exhaust....
Re: Anyone know the specs on the old trw 2293 piston? [Re: 9SecRoadRunner] #737711
07/05/10 07:12 PM
07/05/10 07:12 PM
Glen440 Offline OP
Glen440  Offline OP
Thats impressive.
87 dakota 6.1 hemi
