Anyone know the specs on the old trw 2293 piston?
#737697
06/30/10 09:19 PM
06/30/10 09:19 PM
Posts: 1,397 Toronto Ontario, Can
Glen440
I have a 383 with the .030 trw 2293 domes. I'm curious what the dome cc is.
This engine was built way back in 1980, heads are 906's with double springs and aluminum retainers. Some weird rod bolts with a locking style nut. It has main studs and head studs with a 7 quart pan and HV oil pump. There is no cam in it so no idea what was in it
87 dakota 6.1 hemi
Re: Anyone know the specs on the old trw 2293 piston?
[Re: Glen440]
#737698
06/30/10 09:23 PM
06/30/10 09:23 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I "think" it's 12cc's IIRC.I have the same slugs in my old 383.It's been a long time since we bought those pistons.
[Re: Chris2581]
#737699
06/30/10 09:31 PM
06/30/10 09:31 PM
Glen440
I have been coming up with all different answers searching the web, people saying they are 11.5-1 with 88cc heads which would make the dome huge.
87 dakota 6.1 hemi
[Re: Black_Bee]
#737701
07/01/10 09:19 AM
07/01/10 09:19 AM
Glen440
Maybe a better question is how much cylinder pressure do people have with these?
I'm trying to decide on what head gasket to use, there is a huge difference between 12 and 22 cc.
87 dakota 6.1 hemi
[Re: Glen440]
#737702
07/02/10 11:33 AM
07/02/10 11:33 AM
Posts: 1,307 BC, Canada
Black_Bee
BC, Canada
Its been years since I built my engine, but I'm pretty sure I ended up with 11.3:1 with the pistons .005 in the hole and 88cc edelbrock heads.
I have a small solid cam (232/242) in the engine and it was pushing 195ish psi if I remember correct.
Hope this helps.
Paul '69 Super Bee 383 EFI Turbo
[Re: Glen440]
#737703
07/02/10 02:24 PM
07/02/10 02:24 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
What gas are you trying to use? Mine; .045 in the hole, 1009 gasket, w/82 cc 906s, wouldn't come close to running ok on pump gas even with the timing turned way down. I run C12 , and now have 75cc aluminum -1's on it. Don't know for sure what the compression is, but it ran 130 mph in a 2900# + 67 cuda.
Rem
[Re: dOoC]
#737707
07/04/10 05:09 PM
07/04/10 05:09 PM
Glen440
Thanks everyone
I'm trying to figure out what exactly I'm gonna do with this engine. I have a 440 block getting machined at the moment. My duster needs an engine with the 511 being pretty smashed up. Gonna go back to having fun before I revisit the B1 engine.
If the 383 would run high 10's in a light A body back half car I would put it in it.
87 dakota 6.1 hemi
[Re: Glen440]
#737708
07/04/10 05:42 PM
07/04/10 05:42 PM
Posts: 810 Sidney Ohio
9SecRoadRunner
Sidney Ohio
my brothers duster has those pistons +.060, 590 MP cam, ported 452 heads, all steel car , working windows, factory wiring , lights and heater box etc still in car...runs 10.70's @ 125
You Thinking It's So Doesn't Make It a Fact
[Re: dOoC]
#737710
07/05/10 11:44 AM
07/05/10 11:44 AM
RemCharger
Sk. Canada
Did you have to fly-cut the pistons with the 590 ? ... if so - how much? .....and where did those pistons come-up .. on the deck?
I didn't on mine. .585 comp,275 at .050, amd 1.6 intakes, but they are tight. Around .070 on the exhaust....
[Re: 9SecRoadRunner]
#737711
07/05/10 07:12 PM
07/05/10 07:12 PM
Glen440
Thats impressive.
87 dakota 6.1 hemi
