Early "B" guys, which oil pan for big block? #735624
06/28/10 12:46 PM
06/28/10 12:46 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
Hey all, this past spring I put a 440/4 speed in my 65 Coronet. I used a 7 quart deep oil pan with a 1/2" pickup. This is a street car and I live on county roads. This equates to the oil pan rubbing when 3 or 4 people are in the car. I now have an oil leak.
So, I get to yank it and change the pan. I have a factory 187 pan to put on, but no pickup. I cannot find a 1/2" for this pan.
What pan do you all use that does not hang down? Will the Mopar Hemi pan work? I have the stock 1965 K frame.
Thanks,
Re: Early "B" guys, which oil pan for big block? [Re: nd65] #735625
06/28/10 03:44 PM
06/28/10 03:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Other than the original the 187 is about the only factory pan that will fit the BB early B. You'll have to fabricate your own 1/2" pickup for it.
A Max Wedge pan would be ideal for your situation but try to find one.
Re: Early "B" guys, which oil pan for big block? [Re: John_Kunkel] #735626
06/28/10 04:18 PM
06/28/10 04:18 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
That is what I was afraid of John. I thought I might be able to cut and weld my deep pan 1/2" pick up to work with the factory pan.
Re: Early "B" guys, which oil pan for big block? [Re: nd65] #735627
06/28/10 05:31 PM
06/28/10 05:31 PM
The 1966 to 1969 street hemi pans fit fine in the early B body with the B and RB motors mounted on stock wedge K members with stock mounts Hemi shoulbd mount in the same place due to the trans crossmembers being the same BTW, I stock the Mopar OEM 1/2 oil pick ups for both the early and late B&E body Street Hemi motors with the stock oil pans.The late model 1970-71 street hemi and 440 6 pak pans won't fit in the pre 1966 B body K members with stock mounts
Re: Early "B" guys, which oil pan for big block? [Re: Cab_Burge] #735628
06/28/10 07:38 PM
06/28/10 07:38 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Who sells the early 66-69 hemi pan?
Re: Early "B" guys, which oil pan for big block? [Re: gtx69] #735629
06/28/10 08:22 PM
06/28/10 08:22 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Be careful, the 66-69 K frame is diff than the early K frames. You see the K member is diff moving the engine forward 1 1/2-2" compared to the later 66 up K-frames.
If it were my car, I would clearance the are needed with a carbide Burr and epoxy, or Mig weld up hole. Im pretty sure stock-ish style oil pans will fit with a clearanced K-member in the lip area.
Look at Mancini Racing web site for pans and pics.
I run the SS style pan with the drag link through the pan. My engine was/is at stock location. I located a Milodon pan that worked like a charm.
If you have a truck pan, or 4x4 pan like the Milodon pan I would just use it.
Re: Early "B" guys, which oil pan for big block? [Re: Bob_Coomer] #735630
06/28/10 08:34 PM
06/28/10 08:34 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
What about a Milodon 7 qt low profile pan ?
http://www.milodon.com/oil-pans/street-oil-pans-chrys.asp
Re: Early "B" guys, which oil pan for big block? [Re: 69CHARGERMD] #735631
06/28/10 08:41 PM
06/28/10 08:41 PM
I think he's looking for a better clearance stock type pan to replace his deep sump one...
Not sure that would help much.
383man #735632
06/29/10 12:58 AM
06/29/10 12:58 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use a Moroso pan that fits right in the stock K-frame with no mods at all. I forget if it is listed as a 7 or 8 qt pan but when I put 7 in it thats right below the full line. My 63 is a street car that I drive alot and has never even hit once. You can see it has about 6" of room. I like it alot as I use the 1/2" pickup and as I said it needs no mods at all. Ron
Re: 383man [Re: 383man] #735633
06/29/10 07:39 AM
06/29/10 07:39 AM
Mountains of NM
65superstock Offline
Mountains of NM
I run that pan and I don't have any issues. You do have to clearance the k-member a little though.
-Jason
Re: 383man [Re: 65superstock] #735634
06/29/10 09:43 AM
06/29/10 09:43 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
if you were thinking of cutting and modifying just do it on the pan you have. i made a pan for my 65 thats 5 1/2" deep, holds 7qts. cut the bottom off what you have and make a sump that sticks out both sides like a track pan.
Re: 383man [Re: lewtot184] #735635
06/29/10 12:00 PM
06/29/10 12:00 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ron I run the 66 up Moroso 8 qt in my 65 also.Fit perfect.I just took a tiny piece out of the right K because it cleared but was close.I could have gotten by but liked the extra 1/4 I gained.My pan has been on for 12 years street and never came close to hitting even on Ohios bad roads.I used to run a 67 pan when I first had the 440 in.Ran that for over 25 years.Rocky
Chrysler Firepower
Re: 383man [Re: therocks] #735636
06/29/10 12:25 PM
06/29/10 12:25 PM
6T4 Polara Offline
6T4 Polara  Offline
1964 B body engine stock location 426 street wedge 699 pan.
John
Re: 383man [Re: 6T4 Polara] #735637
06/30/10 07:57 AM
06/30/10 07:57 AM
Mountains of NM
Mountains of NM
Hey 6T4 Polara, That is one PRETTY Polara!!
-Jason
Re: Early "B" guys, which oil pan for big block? [Re: nd65] #735638
06/30/10 03:19 PM
06/30/10 03:19 PM
Parkville,MD.
bigjohn65 Offline
bigjohn65  Offline
Parkville,MD.
have the mopar pan on b block, need to file little spot on k-member.
John
Re: Early "B" guys, which oil pan for big block? [Re: bigjohn65] #735639
07/01/10 08:17 AM
07/01/10 08:17 AM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
Bigjohn65, are you running the 6 Quart hemi pan? My k frame is already notched on the passenger side for pan clearance. How does it fit at the front. Any clearance issues?
Re: Early "B" guys, which oil pan for big block? [Re: nd65] #2848473
11/19/20 06:23 AM
11/19/20 06:23 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Hi moparts,
Will the 6 quart 70/71 hemi pan fit in my 69 charger as the 402 pan is only 5 quarts ?
Many thanx from jon
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: Early "B" guys, which oil pan for big block? [Re: nd65] #2848490
11/19/20 08:34 AM
11/19/20 08:34 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
The new style Moroso pan is the only pan I have found that fits with no cutting - its sits higher than most pans and has the right clearance on the drag link - this is on a 65 coronet 440 - 4-speed - you can also get a 1/2" pick-up for it
Re: Early "B" guys, which oil pan for big block? [Re: Gtxxjon] #2848732
11/19/20 04:17 PM
11/19/20 04:17 PM
Originally Posted by Gtxxjon
Hi moparts,
Many thanx from jon
Yes sir it does up
Those stock 440 6 pack and street hemi 1970/71 6 quart pans fit in B bodies from 1966 to 1971 that I know of up
