Low oil presure 20 30 lbs. #734452
06/26/10 10:00 PM
06/26/10 10:00 PM
NEW YORK
MAXEDWEDGE Offline OP
NEW YORK
Last week i collapsed an oil filter the oil dropped to 20 -30 lbs 15psi @ 1200 & 30 @ 3,000 . I changed the filter and all was good. A week later and its back but the filters ok . I changed the filter, oil pump,-10 line frim miloden pump to pick-up , dropped the pan and cleaned and checked p/u .their was some debrie in the pan but i think its from when i had a valve spring break and chewed up the valve guide . ran a diiferent oil line and oil gauge no change.All the rods look good Any idea's
Re: Low oil presure 20 30 lbs. [Re: MAXEDWEDGE] #734453
06/26/10 10:12 PM
06/26/10 10:12 PM
Remove and check the bypass valve in the pump cover, it should slide in and out by turning the cover up ad down. The valve and spring are mounted at the rear of the cover It is not uncommon for that to happen, especially after someting breaks like a valve spring Let us know what you find
Re: Low oil presure 20 30 lbs. [Re: Cab_Burge] #734454
06/26/10 10:16 PM
06/26/10 10:16 PM
NEW YORK
NEW YORK
did that also , when i bought the new pump i pulled the old check valve and spring and put the new ones in. the old by-pass slid right out . thanks for the input any other idea's
Re: Low oil presure 20 30 lbs. [Re: MAXEDWEDGE] #734455
06/26/10 10:32 PM
06/26/10 10:32 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Did the gauge get damaged? Maybe try a different gauge. Mopar oil pumps are pretty simple. It's usually the bypass that causes grief. It takes a lot to mess up the rotors so bad that the pressure drop significantly.
Pick up tube blocked, cracked or loose?
Re: Low oil presure 20 30 lbs. [Re: MAXEDWEDGE] #734456
06/26/10 10:41 PM
06/26/10 10:41 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Did you check it AFTER you changed the filter??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Low oil presure 20 30 lbs. [Re: torkrules] #734457
06/26/10 11:02 PM
06/26/10 11:02 PM
NEW YORK
NEW YORK
did that x 2. any other idea's
Re: Low oil presure 20 30 lbs. [Re: hemi-itis] #734458
06/26/10 11:04 PM
06/26/10 11:04 PM
NEW YORK
NEW YORK
Yea ..
Re: Low oil presure 20 30 lbs. [Re: MAXEDWEDGE] #734459
06/27/10 11:08 AM
06/27/10 11:08 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I just hope what happen to mine did not happen to yours. Mlne killed a roller lifter and some of it got passed the oil pump up to the rod bearings. But you could see where something had marked up the rotor in the oil pump.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Low oil presure 20 30 lbs. [Re: MRMOPAR622] #734460
06/27/10 06:09 PM
06/27/10 06:09 PM
NEW YORK
NEW YORK
IVE GOT SWIRL MARKS ON THE PUMP COVER WHERE THE PUMP ROTORS SPIN. MY MILODON PUMP COVER IS HARDENED TOO I COULDNT CLEAN IT UP WITH A FILE OR SANDPAPER. IM ALSO RUNNING A ROLLER CAM . THANKS FOR THE INFO IM GOING OUT TO CHECK NOW
Re: Low oil presure 20 30 lbs. [Re: MAXEDWEDGE] #734461
06/27/10 09:01 PM
06/27/10 09:01 PM
NEW YORK
NEW YORK
Found it , just before i started it it backfired bigtime (dont ask) bent 2 pushrods and broke a roller lifter. It aint easy bring me!. 2 different problems wit h the same symptoms. THANKS again to all that helped
