'Cuda Front Elastomeric Bumper -How to Refinish? #731999
06/23/10 02:38 PM
06/23/10 02:38 PM
South Georgia
tx9cuda Offline OP
tx9cuda  Offline OP
South Georgia
I just scored an original Cuda front rubber bumper with mounting brackets. It is in good shape only needing stripping and a repaint. Could anyone who has worked with these before share some do's and don't's on stripping, prepping and painting?
Also - I have read here that there is a difference between '70 & '71. How can I check mine? Any help greatly appreciated
Bryan
1971 BS23H1B
Re: 'Cuda Front Elastomeric Bumper -How to Refinish? [Re: tx9cuda] #732000
06/23/10 04:58 PM
06/23/10 04:58 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
im not an expert but i know the difference between 70-71 is how wide the gap is below.as in front of the nr,plate and then to the sides.maybe the road-lamps will interfere(dont think so).but maybe it like this=the -70 has a wider lower plastic valance insert,and the -71 has a narrower?anyway thats where they differ,in the lower cut-out section off the bumper.hope you got the right one
Re: 'Cuda Front Elastomeric Bumper -How to Refinish? [Re: tx9cuda] #732001
06/23/10 05:04 PM
06/23/10 05:04 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Bryan,
Nice score. The front bumpers are different between 70 and 71, with supposedly early 71 cars getting 70 bumpers. The difference is in the lower lip and how it lines up with the front valence. I think 71 had a small opening than 70 IIRC.
Anyway, if the lower part lines up "close" to your valence opening you have the right one.
As for getting off old paint, I would wet sand it.
Morty
Re: 'Cuda Front Elastomeric Bumper -How to Refinish? [Re: Morty426] #732002
06/24/10 09:01 AM
06/24/10 09:01 AM
South Georgia
tx9cuda Offline OP
tx9cuda  Offline OP
South Georgia
Thanks Morty/Swede
Good info - I will measure tonight and compare to the valence opening on my '70 and hope it matches.
1971 BS23H1B
Re: 'Cuda Front Elastomeric Bumper -How to Refinish? [Re: tx9cuda] #732003
06/26/10 09:35 AM
06/26/10 09:35 AM
South Georgia
tx9cuda Offline OP
tx9cuda  Offline OP
South Georgia
Help-
I would like to strip this bumper myself. Wanted to bump this up again. Would like for someone with experience to comment on proper way to strip old paint from it. I would like to do all I can myself before turning it over to painter.
Bryan
1971 BS23H1B
