stroker crank selection.. #731193
06/22/10 11:41 AM
06/22/10 11:41 AM
Tampa, Fl
valiantboy Offline OP
super gas
super gas
Tampa, Fl
anyone had experience with the 318/340 main cast cranks? i know the eagles are less expencive but are they as good as the mpp units? i just dont want to "cheap out" and have to start allover cus the crank let go. any input?
I'm WAY too baked to drive to the devil's house.
Re: stroker crank selection.. [Re: valiantboy] #731194
06/22/10 12:03 PM
06/22/10 12:03 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
MP are made by Scat...so find the best price on a Scat or MP...same crank
Tony
70 AARCuda Vitamin C
Re: stroker crank selection.. [Re: 70AARcuda] #731195
06/22/10 01:01 PM
06/22/10 01:01 PM
wisconsin
1BAD68 Offline
1BAD68  Offline
wisconsin
I'm running an Eagle cast crank in my 318 stroker and beat on it mercilessly with no problems, going on 3 years.
Re: stroker crank selection.. [Re: 70AARcuda] #731196
06/22/10 01:02 PM
06/22/10 01:02 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
i used the ohio crankshaft cast 4" stroke crank in my 340 stroker,a nice crank, sizes were on the money,mine needed 3 slugs of mallory to internal balance,i used scat i-beams rods and diamond dish forged pistons.mike
Re: stroker crank selection.. [Re: hp340nos] #731197
06/22/10 03:35 PM
06/22/10 03:35 PM
Tampa, Fl
super gas
super gas
Tampa, Fl
im sure every manufacturer has issues. i guess its a shot in the dark.
Re: stroker crank selection.. [Re: valiantboy] #731198
06/22/10 05:45 PM
06/22/10 05:45 PM
Tampa, Fl
super gas
super gas
Tampa, Fl
anyone know if campbell enterprises has a discount code for moparts members?
Re: stroker crank selection.. [Re: valiantboy] #731199
06/22/10 05:50 PM
06/22/10 05:50 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
What is your expected horsepower output? If it's under 450 (which is easy to reach with good heads) then the Eagle cast is an option. If you expect to exceed that figure at all, ever, I would go with a better crank like a K1.
Re: stroker crank selection.. [Re: moper] #731200
06/22/10 06:35 PM
06/22/10 06:35 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
I'm running almost 500 hp with my 408 using a cast Eagle crank spinning up to about 5,500. No malory needed to internal balance.
Re: stroker crank selection.. [Re: PAINT IT BLACK] #731201
06/22/10 09:42 PM
06/22/10 09:42 PM
Tampa, Fl
super gas
super gas
Tampa, Fl
should be 450-475hp. around there. my older 360 was right there.. cast crank and factory rods. never had a problem. i doubt itll see 6500rpm ever. probly not even 6000. well except for the floggings at the track.
