Page 4 of 5 1 2 3 4 5
Re: Updated [Re: gtx6970] #730797
12/02/10 11:01 PM
12/02/10 11:01 PM
It's a dry heat
gtx6970 Online content OP
gtx6970  Online Content OP
It's a dry heat
a more overall view
Re: Updated [Re: gtx6970] #730798
12/02/10 11:03 PM
12/02/10 11:03 PM
It's a dry heat
It's a dry heat
Didn't like the idea of hanging a ECU on the firewall( neither did the owner )
So,
Re: Updated [Re: gtx6970] #730799
12/02/10 11:04 PM
12/02/10 11:04 PM
It's a dry heat
It's a dry heat
Viola,
Re: Updated [Re: gtx6970] #730800
12/02/10 11:06 PM
12/02/10 11:06 PM
It's a dry heat
It's a dry heat
Spent this morning dis-assembling 1/4 window glass and trim.
The tinted glass had 71-74 trim on it,so I took all of the apart to transfer the 70 only trim that was on the clear glass but needs to be on the tinted glass going in the car.
70 is on the right and the later ones on the left
Re: Updated [Re: gtx6970] #730801
12/02/10 11:20 PM
12/02/10 11:20 PM
It's a dry heat
It's a dry heat
Seats are done to !
Re: Updated [Re: gtx6970] #730802
12/02/10 11:21 PM
12/02/10 11:21 PM
It's a dry heat
It's a dry heat
Major plus for an E-body. Adding a 6 way seat
Re: Updated [Re: gtx6970] #730803
12/02/10 11:26 PM
12/02/10 11:26 PM
It's a dry heat
It's a dry heat
on a side note.
If your glass has scratches in them, don't bother with the Eastwood polishing kit. about all it's good for is removing haze
Re: Updated [Re: gtx6970] #730804
12/02/10 11:44 PM
12/02/10 11:44 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Lookin good Bill. If the AC compressor lines up correctly to use 2 belts as the original does...I'd use them. I've got Classic Air brackets on a small block, and it only uses one belt. It will squeel under load sometimes. Use 2 if you can.
Re: Updated [Re: JDMopar] #730805
12/03/10 10:38 AM
12/03/10 10:38 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Very nice Bill. Looks like a sweet ride.
Re: Updated [Re: Dave Watt] #730806
12/03/10 11:43 AM
12/03/10 11:43 AM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Looking great Bill!
65 Barracuda
70 Challenger
Re: Updated [Re: JDMopar] #730807
12/03/10 07:13 PM
12/03/10 07:13 PM
It's a dry heat
It's a dry heat
Thanks fellas
JD,
I tried and would prefer 2 belts, BUT the pulley alignment makes that out of the question.It's one belt or nothing.
Re: Updated [Re: gtx6970] #730808
12/03/10 08:54 PM
12/03/10 08:54 PM
CANADA
Desmond Offline
Desmond  Offline
CANADA
really cool build!
Re: Updated [Re: Desmond] #730809
12/04/10 12:30 PM
12/04/10 12:30 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Coming along nicely!!
Great find as far as speakers!
I had no idea 1/4 trim was different in 70.
I love the location of the ECU!
Re: Updated [Re: gtx6970] #730810
12/04/10 06:27 PM
12/04/10 06:27 PM
Canada
70RT70 Offline
70RT70  Offline
Canada
Nice Project!
Re: Updated [Re: wally426ci] #730811
12/04/10 07:23 PM
12/04/10 07:23 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Me either, is that just a Barracuda thing or was diff. on 70 Challengers also?
Joe
Re: Updated [Re: jrwoodjoe] #730812
12/05/10 05:23 PM
12/05/10 05:23 PM
It's a dry heat
It's a dry heat
Joe
Joe, as a far as I know Yes it applies to all E-bodies.
The vertical weatherstrip in this stainless steel moulding is unique to a 1970
Re: Updated [Re: gtx6970] #730813
12/07/10 08:19 PM
12/07/10 08:19 PM
London, England
Gavin Offline
Gavin  Offline
London, England
Bill did you replace the rubber trim at the base of the quarter glass as well - I guess you might call it window channel? If so what did you use, thanks
Re: Updated [Re: Gavin] #730814
12/07/10 10:59 PM
12/07/10 10:59 PM
It's a dry heat
It's a dry heat
Gavin,
If your talking about the strip thats keeps the glass in the lower aluminum lift plate ?
No , I just want to transfer the stainless trim from the leading edge to the tinted glass.
btw, 3M makes a 2 part adhesive to attach the glass to the lift plate as well as the stainless trim
Re: Updated [Re: gtx6970] #730815
12/08/10 01:19 AM
12/08/10 01:19 AM
long island new york
K
kingdust Offline
kingdust  Offline
K
you do nice work. attention to details makes or breaks a car. its alot of work and its nice when you have the parts already there, seems like your getting alot done in a short amount of time. good luck finishing it.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: Updated [Re: kingdust] #730816
12/09/10 11:36 AM
12/09/10 11:36 AM
It's a dry heat
It's a dry heat
was just playing around over the weekend.
15x7 on the front with way to tall 225-70R15's
and 15x8's with 275-60-15's on the rear
