Page 3 of 5 1 2 3 4 5
Re: Updated [Re: gtx6970] #730777
10/28/10 09:54 AM
10/28/10 09:54 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Finally found dash speakers that fit without to much majory surgery to the dash frame.
These are Clarion 3.5" 2 ways . They fit the grille perfectly, and I only had to trim the metal dash frame maybe 3/4" of an inch.
top view
Re: Updated [Re: gtx6970] #730778
10/28/10 09:55 AM
10/28/10 09:55 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
view from the bottom( left front speaker)
Re: Updated [Re: gtx6970] #730779
10/28/10 09:58 AM
10/28/10 09:58 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Vintage Air a/c box is all done and mounted using home made brackets to avoid drilling anything extra in the car
Re: Updated [Re: gtx6970] #730780
10/28/10 09:59 AM
10/28/10 09:59 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Dash is , for the most part done. and now in the car.
Re: Updated [Re: gtx6970] #730781
10/28/10 10:01 AM
10/28/10 10:01 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Drivers side view
Used the metal woodgrain applique from PG, and gauge overlays from Mister Heater box
Re: Updated [Re: gtx6970] #730782
10/28/10 10:06 AM
10/28/10 10:06 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Yesterday I concentrated on engine wiring and ignition system cleanup
Due to the a/c compressor mounting location. Using the factory Hemi coil mount was out of the question.
So, I'm using a Accell coil
mounted on the rear/ side of the intake, similar to a 440 six pack mounting .
Fabbed up a bracket yesterday with some leftover 18 gauge stainless and a bench vise. It's not super pretty, but once painted and the coil is mounted. You not going to see it anyway.
Re: Updated [Re: gtx6970] #730783
10/28/10 10:10 AM
10/28/10 10:10 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
This is the coil I'm going with. And once the air cleaner is on it your not going to really see the coil anyway, which is kind of the point.
Re: Updated [Re: gtx6970] #730784
11/03/10 10:56 AM
11/03/10 10:56 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
Bill, do you know what the chrome paint was that was used on inside of tail light housings ? Looks good in pics - what is real world look with brakes applied - does it reflect nicely - thanks - Joe
Re: Updated [Re: shakerjoe] #730785
11/04/10 07:27 PM
11/04/10 07:27 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Jpoe,
I'll ck the can leftovers I have. and post a pt # and brand
I can't answer on the reflective quality as of yet, as the car isn't done .
I felt it looked very close to the original satin chrome look of the original hsgs.
Re: Updated [Re: gtx6970] #730786
11/10/10 06:36 AM
11/10/10 06:36 AM
Adelaide Australia
P
peter Offline
peter  Offline
P
Adelaide Australia
Hello
Can you please tell me where you got the aircon compressor brackets from
thank you
peter
Re: Updated [Re: peter] #730787
11/12/10 10:49 AM
11/12/10 10:49 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Hello
thank you
peter
http://www.bouchillonperformance.com/
Re: Updated [Re: gtx6970] #730788
11/18/10 09:49 AM
11/18/10 09:49 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Well, The body is out having the vinyl top, Ft and rear glass and headliner installed I turned my atention to the interior trim.
My customer decided not to wait on the upcoming new interior trim panels.
So, I cleaned, cleaned and cleaned again all 4 of the originals. dyed them with Sems brand vinyl dye with an adhesion promotor. Should there be a problem later one, he may re-evaluate the new ones.
I think they came out great, these were not perfect, but very nice used originls.
Ft's
Re: Updated [Re: gtx6970] #730789
11/18/10 09:50 AM
11/18/10 09:50 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
2
Re: Updated [Re: gtx6970] #730790
11/18/10 09:51 AM
11/18/10 09:51 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
3
Re: Updated [Re: gtx6970] #730791
11/18/10 09:52 AM
11/18/10 09:52 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
kick panels
Re: Updated [Re: gtx6970] #730792
12/01/10 05:22 PM
12/01/10 05:22 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Car is back from the trim shop. Had the top and headlier installed. As well as polishing all the exterior stainless trim. New windshield and rear glass installation
Re: Updated [Re: gtx6970] #730793
12/02/10 10:55 PM
12/02/10 10:55 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
It's starting to look like the mans dream ride. Tires and wheels are just rollers for now
Re: Updated [Re: gtx6970] #730794
12/02/10 10:58 PM
12/02/10 10:58 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Getting the underhood A/C system mocked up and trial fitted, so far I'm impressed. It took a little bit of tweaking on the hard line to the drier but thats about it
Re: Updated [Re: gtx6970] #730795
12/02/10 10:59 PM
12/02/10 10:59 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
top view
Re: Updated [Re: gtx6970] #730796
12/02/10 11:00 PM
12/02/10 11:00 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
again
