Page 2 of 5 1 2 3 4 5
Re: Updated [Re: gtx6970] #730757
09/24/10 09:57 AM
09/24/10 09:57 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Original lenses and chrome bezels are all polished up, everything back in the car.
Re: Updated [Re: gtx6970] #730758
09/24/10 09:59 AM
09/24/10 09:59 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Last one for now.
Replated trunk latch and hardware.
Lock cover was powder coated gloss back and the finished and installed tail light.
Re: Updated [Re: gtx6970] #730759
09/24/10 11:32 AM
09/24/10 11:32 AM
MI
68shifter Offline
68shifter  Offline
MI
Awesome attention to detail. Cudas just look good green. Is that going to be a stick or auto car?
Keep up the good work, and the updates.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: Updated [Re: 68shifter] #730760
09/24/10 01:50 PM
09/24/10 01:50 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Looks really nice Bill. He's gonna be so stoked when he gets it back.
Joe
65 Barracuda
70 Challenger
Re: Updated [Re: jrwoodjoe] #730761
09/24/10 07:13 PM
09/24/10 07:13 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Updated [Re: BloFish] #730762
09/29/10 09:02 AM
09/29/10 09:02 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Looking forward to more pics, Looking good
Re: Updated [Re: Finoke] #730763
10/08/10 06:34 PM
10/08/10 06:34 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Been working on it all week. Like previously stated, it gets A/C . Took several attempts to get everything lined up.
Everything on the motor came from Buochillon,,, from the compressor to all the brackets, including the power master alternator.
IMO, use the supplied instructions as a guide, I ended up moving spacers and washers around to make it fit to where I was happy.
Re: Updated [Re: gtx6970] #730764
10/08/10 06:36 PM
10/08/10 06:36 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Sanden compressor.
This is just a trial fit, as the owner wants it painted black before final installation
Re: Updated [Re: gtx6970] #730765
10/08/10 06:37 PM
10/08/10 06:37 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
So much for the factory coil mounting.
( ps,and yes that little spring bracket is already painted engine color)
Re: Updated [Re: gtx6970] #730766
10/09/10 09:53 AM
10/09/10 09:53 AM
Port Saint Lucie, FL
ChallengerGary Offline
Incredible!!!
Re: Updated [Re: 68shifter] #730767
10/10/10 09:30 PM
10/10/10 09:30 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
It's going to be a console auto. He had John Cope build the trans with several internal upgrades in the name of safety and performance. With a PTC 3000 stall 9.5" convertor for it as well
Re: Updated [Re: gtx6970] #730768
10/21/10 09:48 AM
10/21/10 09:48 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Well, It's been kind slow going. having to rework most of the repop parts brought in.
Here is the repop OIL dipstick tube to manifold bracket.
As you can see the bracket is bent completely opposite of the way it needs to be.
Re: Updated [Re: gtx6970] #730769
10/21/10 09:49 AM
10/21/10 09:49 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
I ended up bending - making a new bracket to attach the tube to the manifold and hold it in place
Re: Updated [Re: gtx6970] #730770
10/21/10 09:52 AM
10/21/10 09:52 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Got all the allignment issues with the A/C compressor, power steering and alternator straightend out.
Compressor is painted the black he wants it and is on for the last time.
Bouchillon recomended the saginaw power steering pump and brackets.
Re: Updated [Re: gtx6970] #730771
10/21/10 09:54 AM
10/21/10 09:54 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
So much for the pre-bent fuel pump to seperator line. This one went in the trash
Re: Updated [Re: gtx6970] #730772
10/21/10 09:57 AM
10/21/10 09:57 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
1 new line and a little bit of time with a tubing bender and it's all better now.
Re: Updated [Re: gtx6970] #730773
10/21/10 10:00 AM
10/21/10 10:00 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Tim Banning recomended not to use the choke tubes, and the fact the car has an electric choke , means the tubes are for looks only.
Re: Updated [Re: gtx6970] #730774
10/21/10 10:03 AM
10/21/10 10:03 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
All together and,anyone will be hard pressed to tell.
Repop trans dipstick tube and indicator fit perfectly
Re: Updated [Re: gtx6970] #730775
10/21/10 10:05 AM
10/21/10 10:05 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
A couple friends dropped by sunday afternoon,,,, and like Prego, it's in there.
Re: Updated [Re: gtx6970] #730776
10/21/10 10:06 AM
10/21/10 10:06 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
View from the other side
It went in from the bottom as engine, trans, and K-frame exactly as you see it.
To say it was tight fit is an understatement. Once it got close , Coming down with the lift at about 1/2" increments takes a while. But we didn't scratch anything
