Page 1 of 5 1 2 3 4 5
Painted 14 years ago, it's time to put it together #730737
06/21/10 10:12 PM
06/21/10 10:12 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
1970 Cuda
After nearly 3 years of ribbing him, I got the job to assemble the mans dream. The body was painted in 1995 or 96 and has sat covered ever since. He's owned it since about 1982 or 83'
ps, yes, it's a real AAR but it was missing all it's original drivetrain back then. Considering how longed he's owned it. The chances he's gonna sell it anytime soon is very unlikley. So, he decided to build his dream car. I assure you he will die with this car in his ownership.
Re: Mix a little dis and just a dash of that + You get [Re: gtx6970] #730738
06/21/10 10:13 PM
06/21/10 10:13 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Mix in a bit of dis
Re: Mix a little dis and just a dash of that + You get [Re: gtx6970] #730739
06/21/10 10:16 PM
06/21/10 10:16 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Powered by
Tim Banning built 470 plus cuin monster
Re: Mix a little dis and just a dash of that + You get [Re: gtx6970] #730740
06/21/10 10:20 PM
06/21/10 10:20 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Plan was to have it ready for the Nats, but I think Sept and Monster Mopar show is more realistic
Re: Mix a little dis and just a dash of that + You get [Re: gtx6970] #730741
06/21/10 11:19 PM
06/21/10 11:19 PM
Port Saint Lucie, FL
ChallengerGary Offline
Bill,
Something like this?
Gary
Updated [Re: ChallengerGary] #730742
09/24/10 09:03 AM
09/24/10 09:03 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Been kinda busy with other projects so progress is slow .
But it's at least progress
Spent to better part of 2 days insulating the inside of the passenger compartment. From roof to floor and firewall to speaker shelf.Inside of the doors and 1/4 area will get covered as well, once all the regualtors and glass are in and adjusted.
Re: Updated [Re: gtx6970] #730743
09/24/10 09:06 AM
09/24/10 09:06 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Park brake assy, Steering column support, and the vent box have all been done and re-installed.
Re: Updated [Re: gtx6970] #730744
09/24/10 09:11 AM
09/24/10 09:11 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Roof is insulated front to rear. You wouldn't believe how solid the roof sounds when you tap on it,no more ting ting when you hit it, now it's a solid 'thud'. I think it's going to be much quieter inside.
I went with a fatmat.com material called 'rattle trap'
Re: Updated [Re: gtx6970] #730745
09/24/10 09:18 AM
09/24/10 09:18 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Car gets a Vintage Air a/c system , thus why theres a bare spot on the firewall.
My one pet peave with this system is how the box mounts.
I plan to make a new heater-a/c box mounting brackets to use the original non-a/c box mounting points, that way theres no extra holes to be drilled into the firewall.
Re: Updated [Re: gtx6970] #730746
09/24/10 09:24 AM
09/24/10 09:24 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Rear end is an all new Strange 3.54 Dana. Using 1" offset shackles to allow a bit more tire under the car. Hung on AAR arched Hemi style springs from Detroit spring ( bushings are now in btw)
Shocks are KYB's painted to replicate something close to OE.
Re: Updated [Re: gtx6970] #730747
09/24/10 09:28 AM
09/24/10 09:28 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Neil at Dynamic Renovation did some plating for me. From the door latches and strikers to jack mast, every piece came back looking great.
Latches
Re: Updated [Re: gtx6970] #730748
09/24/10 09:30 AM
09/24/10 09:30 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Drivers door latch and striker are in and adjusted, but I'm sure they have to be re-adjusted once the weatherstriping goes on.
Re: Updated [Re: gtx6970] #730749
09/24/10 09:31 AM
09/24/10 09:31 AM
Minnesota
peabodyracing Offline
Minnesota
You're making me feel very bad. My 69 Roadrunner was painted in 96 and I've still not gotten to putting it back together.
Good progress pictures. Thanks for posting!
Re: Updated [Re: gtx6970] #730750
09/24/10 09:32 AM
09/24/10 09:32 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Jack assembly was taken apart , mast replated and all the mechanisims glass beaded and repainted in dove grey.
Re: Updated [Re: gtx6970] #730751
09/24/10 09:33 AM
09/24/10 09:33 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Back together
Re: Updated [Re: peabodyracing] #730752
09/24/10 09:37 AM
09/24/10 09:37 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Don't feel bad, this body was painted in 1993-94 time frame. Most of the parts he bought for it back in the 90's . Dash wiring and interior soft trim were dated 1994 - 1995 respectivily.
Engine was picked up in 2005 I think.
Re: Updated [Re: gtx6970] #730753
09/24/10 09:41 AM
09/24/10 09:41 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Tail lights were ugly to say the least.
Trying to keep something of a budget, the customer asked to see what could be done. The housings were glassbeaded to bare metal.
Re: Updated [Re: gtx6970] #730754
09/24/10 09:42 AM
09/24/10 09:42 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Insides were done with a chrome paint.
Re: Updated [Re: gtx6970] #730755
09/24/10 09:46 AM
09/24/10 09:46 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
The next day. The exterior was sprayed with Eastwoods carb renew paint. This stuff goes on kinda thin so it takes a few coats to get what I felt was a good color match.
shown with camera flash
Re: Updated [Re: gtx6970] #730756
09/24/10 09:47 AM
09/24/10 09:47 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
without camera flash.
outside in natural light.
