426 hemi carter afb float specs #730190
06/21/10 10:11 AM
06/21/10 10:11 AM
englewood beach, florida
ts70rt Offline OP
ts70rt  Offline OP
Can someone help me with some specs on a set of carter afbs on a 68 426. The front carb is dumping fuel bad. Hydro locked motor cranking. The floats are way off. What is the closed height and open or drop on the float. Thanks any help greatly appreciated.
Re: 426 hemi carter afb float specs [Re: ts70rt] #730191
06/21/10 11:21 AM
06/21/10 11:21 AM
Arizona
az426john Offline
az426john  Offline
Arizona
I can't specifically give you the 68 specs, but this is what I have.
1967 Front:
Float Setting - 5/16"
Float Drop - 3/4"
1967 Rear:
Float Setting - 7/32"
Float Drop - 3/4"
1968 - All
Float Drop - 3/4"
Re: 426 hemi carter afb float specs [Re: az426john] #730192
06/21/10 12:27 PM
06/21/10 12:27 PM
ts70rt Offline OP
ts70rt  Offline OP
Thanks alot!
Re: 426 hemi carter afb float specs [Re: ts70rt] #730193
06/21/10 01:24 PM
06/21/10 01:24 PM
Arizona
az426john Offline
az426john  Offline
Arizona
Sorry, I mis-typed 68 should have been 69. Personally, I would follow the numbers for 1969 and you will certainly be in the ball park.
It is possible that you have a leaky float also.
