What do YOU USE ...to file-fit your rings ..?
#727902
06/19/10 02:33 AM
06/19/10 02:33 AM
Posts: 30,474 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
.... it has been ages since I have done this ...and the last time I did-it ...it was a PITA with the one I had(it was red in-color). That was lost-in-the-move ..... so I beeez needin' one ... I have 3 motors to do within the next 45 days or so ..... I don't think that an electric one is in-the-budget .... but if it is a time-saver and more accurate - maybe I can see that through... Give me your
Re: What do YOU USE ...to file-fit your rings ..?
[Re: dOc !]
#727904
06/19/10 07:53 AM
06/19/10 07:53 AM
Posts: 52,972 Romeo MI
MR_P_BODY
[Re: Challenger 1]
#727906
06/19/10 08:23 AM
06/19/10 08:23 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I just us a small fine file in a small vice doing one side using the top of the vice jaws as a guide and take your time.
[Re: Dodgem]
#727907
06/19/10 11:21 AM
06/19/10 11:21 AM
dOc !
Florida STAYcation
THX guys ... So C1 ... you feel that the electric one is tooo aggressive ? And then on the other end of the scale is the hand-file in a vise ?? ... A WIDE-RANGE of opinions here ..... COOL ...
[Re: dOc !]
#727908
06/19/10 01:58 PM
06/19/10 01:58 PM
Posts: 20,894 A collage of whims
topside
A collage of whims
We sell a tool for that: hand-operated, lifetime guarantee on its diamond grinding disk. www.area51groupllc.com, also on Ebay as seller topside340. We sell 'em to Summit & Jeg's. We also have valve spring testers, height mics, leakdown testers, oil filter cutters, rod-bolt stretch indicators, and rearend setup tools.
[Re: BSB67]
#727912
06/19/10 06:41 PM
06/19/10 06:41 PM
Posts: 2,119 sc
tjmarcus1
sc
Simple, and the results are pretty good
that will work well! of course it isn't expensive enough. you need to price at 99.95, then we will like it.
[Re: BSB67]
#727913
06/19/10 07:06 PM
06/19/10 07:06 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
That's about all I am willing to spend on filing rings, and really it's all you have to spend. Simple thing you can do instead of paying big for someone else to do it.
[Re: dOc !]
#727914
06/19/10 07:09 PM
06/19/10 07:09 PM
Challenger 1
Cincinnati, Ohio
THX guys ...
No it's just too light duty and chessey. Motor will bog down if you get in hurry and it's easy to file em outta square. At least with tool steel rings. I haven't used it much with moly rings that I can think of.
[Re: dOc !]
#727916
06/19/10 11:18 PM
06/19/10 11:18 PM
Posts: 43,286 Bend,OR USA
Cab_Burge
I have used the Speed Pro hand operated ring filer(like the Summit one) for years, and then I bought the Proform electric filer I have messed up several moly rings by not taking my time to make sure they where cut square Once I got the hang of it it is way better Don't forget the top moly ring is way harder than the second cast iron ring found in most H.P. file to fit ring sets, the second ring needs a lot less time against the grinding wheel The electric ring filer makes the time seem as twicre to three times faster than using the hand crank Speed Pro filer and nine times faster than usig a file
[Re: kens avenger]
#727921
06/20/10 11:24 AM
06/20/10 11:24 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I prefer to just take a chisel and just pinch off the ring until it will fit in the bore. Who gives a crap about gap. Then grind nothes in the top ring for gas ports.
Just kidding.........
I have a hand crank one. Problem was the hard rings I was forced to run in my ole nitrous motor eat the wheel up. Plus the ring was 4.255" and I was cutting for a .040" gap in a 4.245" bore. Found a cut off wheel to get it close then file to perfection.
I have noticed people really concerned about how square the cut is and even throughing rings they screwed up away. But, will stick a ring they didn't debur in a new piston and trash the ring groove.
Hint... It is more important how well the top ring seals against the bottom of the groove and second seals against the top of it's groove than how perfect you gap the ring. Have seen some hard core guys order the piston with grooves .0005 narrower and then sand the ring's surface down for the desired fit. This idea was around long before the diamond finish deal from Total Seal.
Leon
