Strip elecrocoat from interior quarter panel?? #726149
06/16/10 08:13 PM
06/16/10 08:13 PM
AZ - The "dry heat" state
71autoxr Offline OP
71autoxr  Offline OP
I just finished one side install of an AMD quarter panel on an A-body (nice fit and quality, but that's not for this post).
I have stripped off the black electrocoat from the exterior before spraying epoxy primer. I am going to use 3M body Schutz on the inner of the quarter panel to give it a factory look. Do I need to remove the electrocat before spraying, or am I ok to go over it in this case?
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
Re: Strip elecrocoat from interior quarter panel?? [Re: 71autoxr] #726150
06/16/10 08:16 PM
06/16/10 08:16 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I think you can just scuff it and spray over it.
I bought a car that came with a new repo hood that was coated, and it got lightly sanded and then primed and painted with no issues.
Re: Strip elecrocoat from interior quarter panel?? [Re: 71autoxr] #726151
06/16/10 08:48 PM
06/16/10 08:48 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Why would you want to strip off the E coat? E coat is a better corrosion preventer then any spray on primer. Don't strip it off. Not even on outer side of panels. Just sand it prime or seal and top coat.
Re: Strip elecrocoat from interior quarter panel?? [Re: Dougsmopars] #726152
06/17/10 06:11 AM
06/17/10 06:11 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I'm not sure I agree with that, but for the inside it doesn't matter I have left cars sit out with just ecoated panels and after a year or so they rust. Where cars I epoxied and left sit out, just some fading. I'd scuff it good and coat it.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Strip elecrocoat from interior quarter panel?? [Re: Silver70] #726153
06/17/10 05:45 PM
06/17/10 05:45 PM
Dougsmopars Offline
Dougsmopars  Offline
The point of E coat is not to let it sit out side unpainted. My point is why would you strip off the E coat? You just sand it prime or seal it and paint it. Every new car built in the last 20 years is E coated sealed and painted. You don't see newer cars rusted out in a couple of years like you used to. I've been doing body work and paint for 35 years. We never strip off E coat on new parts unless there junk made in China aftermarket. And we only use the aftermarket on older cars when insurence companies won't pay for OEM.
