Page 4 of 4 1 2 3 4
Re: Who's best at steering wheel restorations [Re: stwheels] #725642
09/02/10 02:49 PM
09/02/10 02:49 PM
New Berlin,Wi
Firepowerflyer Offline
New Berlin,Wi
What is the starting cost/average restoration for a 69 three spoke (wood) wheel?It's in pretty nice shape only one crack or seperation.
Thanks Joe
Re: Who's best at steering wheel restorations [Re: Firepowerflyer] #725643
09/02/10 04:07 PM
09/02/10 04:07 PM
Edmonton , Alberta , Canada
stwheels Offline
stwheels  Offline
Thanks Joe
Hi Joe, if you e-mail me at : stwheels@shaw.ca
I can send you a list of questions I need answered to give a price and turnaround time.
Thanks, Doug
6173994-Sportwheel#11 (71 downloads)
Doug Lepak
Re: Who's best at steering wheel restorations [Re: stwheels] #725644
09/02/10 11:48 PM
09/02/10 11:48 PM
Oh
His and Her 69's Offline
Oh
I have a Good 69 wood grain wheel that has been sitting for sometime and the spokes have some medium/light surface rust starting.
WHAT would be a Good thing to use on them???
A liquid cleaner, 000 steel wool, SOS pad, etc????
It has rust right up against the wood part and I don't want to damage the wood.
Thanks for any suggestions you can give me.
David
Re: Who's best at steering wheel restorations [Re: His and Her 69's] #725645
09/03/10 12:37 AM
09/03/10 12:37 AM
stwheels Offline
stwheels  Offline
David
Hi David, any mild cleaning agent or gel rust remover will get light surface rust off. Whenever you rub the spokes with anything always go down the length of the spokes, never in circles or across the spokes.
For any rust spots in pits and along the recessed lines down the length of the spokes and around the rectangular openings in the spokes you can use a bamboo skewer to pick out the rust. The bamboo is hard enough to dislodge the corrosion but soft enough not to damage/scratch the plating. A pointed skewer is great for rubbing off that surface rust up near the rim too. The strands on the length of the bamboo are fairly tough so you can put a little metal cleaner on the rust, let it soften any crud for a while and then use the skewer to rub off the rust and such.
Once all the rust is removed to your satisfaction you can use a non abrasive metal cleaner on the spokes followed by carnuba wax. Spread the wax all over the spokes and let it dry thoroughly before buffing with a soft rag or microfiber towel.
If you've been careful the spokes will come out with a beautiful satin sheen that will be protected by the wax.
Doug Lepak
Re: Who's best at steering wheel restorations [Re: stwheels] #725646
09/03/10 03:56 AM
09/03/10 03:56 AM
Oh
Oh
Thanks Doug for the tips.
I will have to try it after we get back from the races this weekend.
Any brand of product you like Best???
Thanks Again.
David
Re: Who's best at steering wheel restorations [Re: His and Her 69's] #725647
09/03/10 01:18 PM
09/03/10 01:18 PM
stwheels Offline
stwheels  Offline
Thanks Again.
David
Your Welcome David! Good Luck at the track this weekend
I use a rust removing gel made by Dominion Sure Seal ltd. It's just an off the shelve product that is available at Canadian Tire here in Canada. I'm sure there is something similar at any one of the many auto stores in your area.It's made for removing rust from any plated surface and leaves a protective coating to prevent further problems.
I also use Mothers mag polish. Remember never use a mechanical polishing device (Dremel etc ...) as they are too aggressive and will leave the surface too shiny. The best material I found is microfiber cloth and make sure you only rub down the length of the spokes, never in circles or across the spoke.
For extra protection a bit of Carnuba wax will seal the deal.
Doug Lepak
Re: Who's best at steering wheel restorations [Re: stwheels] #725648
09/15/10 09:02 PM
09/15/10 09:02 PM
stwheels Offline
stwheels  Offline
Boats got wheels too! This is a customers vessel in Ontario, I also refinished the Ivory dash piece.
Doug Lepak
Re: Who's best at steering wheel restorations [Re: stwheels] #725649
10/11/10 06:33 PM
10/11/10 06:33 PM
San Gabriel, CA 91775
rexus31 Offline
rexus31  Offline
I used Quality Restorations in Poway, CA for the wheel and shift knob for my '65 300 Convertible restoration. Dennis does phenomenal work in pouring the new parts which are guaranteed to not crack or fade for as long as I own the car. He even made a mold for the shift knob and poured both in the original color which he told me was Rose Pearl.
http://www.qualityrestorations.com/
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue 1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red 1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red "What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
Page 4 of 4 1 2 3 4
