Re: Who's best at steering wheel restorations
[Re: His and Her 69's]
#725645
09/03/10 12:37 AM
09/03/10 12:37 AM
Posts: 1,947 Edmonton , Alberta , Canada
stwheels
I have a Good 69 wood grain wheel that has been sitting for sometime and the spokes have some medium/light surface rust starting. WHAT would be a Good thing to use on them??? A liquid cleaner, 000 steel wool, SOS pad, etc???? It has rust right up against the wood part and I don't want to damage the wood. Thanks for any suggestions you can give me. David
Hi David, any mild cleaning agent or gel rust remover will get light surface rust off. Whenever you rub the spokes with anything always go down the length of the spokes, never in circles or across the spokes.
For any rust spots in pits and along the recessed lines down the length of the spokes and around the rectangular openings in the spokes you can use a bamboo skewer to pick out the rust. The bamboo is hard enough to dislodge the corrosion but soft enough not to damage/scratch the plating. A pointed skewer is great for rubbing off that surface rust up near the rim too. The strands on the length of the bamboo are fairly tough so you can put a little metal cleaner on the rust, let it soften any crud for a while and then use the skewer to rub off the rust and such.
Once all the rust is removed to your satisfaction you can use a non abrasive metal cleaner on the spokes followed by carnuba wax. Spread the wax all over the spokes and let it dry thoroughly before buffing with a soft rag or microfiber towel.
If you've been careful the spokes will come out with a beautiful satin sheen that will be protected by the wax. ![](/ubbthreads/images/graemlins/beer.gif)
Doug Lepak
[Re: stwheels]
#725649
10/11/10 06:33 PM
10/11/10 06:33 PM
Posts: 366 San Gabriel, CA 91775
rexus31
I used Quality Restorations in Poway, CA for the wheel and shift knob for my '65 300 Convertible restoration. Dennis does phenomenal work in pouring the new parts which are guaranteed to not crack or fade for as long as I own the car. He even made a mold for the shift knob and poured both in the original color which he told me was Rose Pearl. http://www.qualityrestorations.com/![](http://i28.photobucket.com/albums/c206/rexus31/Interior6.jpg)
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue
1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red
1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red
"What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
