400 external flexplate #725382
06/15/10 09:19 PM
06/15/10 09:19 PM
Northeastern, Pa
P
Purphaz Offline OP
Purphaz  Offline OP
P
Northeastern, Pa
Hello. I'm in a state of confusion. I'm looking for any sources on how I can obtain a correct flex plate for my 400 in my 74 Road Runner. The engine has a year "76" casting. The transmission is a Torqueflight.
The terrible vibration the car has, has let to a faulty 360 flex plate that someone drilled to make it work for the 400. The gentleman performing the transmission repair informed me that I need a wide ring gear, 2 weight, offset bolt pattern flex plate that will fit a 10 3/4 - 11 in torque converter.
This gentleman has requested such a flex plate twice and has received the wrong bolt pattern. The piece is for a 360. The supplier instructed him to simply re-drill and adapt to the 400, however, that is already the case.
I appreciate all your help.
Re: 400 external flexplate [Re: Purphaz] #725383
06/15/10 09:30 PM
06/15/10 09:30 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
look at b&m 10237
Chrysler '71 & later externally balanced 383, 400, 440 with cast crank and A-727 (These special Chrysler Flexplates must be used when changing converters on an externally balanced engine.)
Tony
70 AARCuda Vitamin C
Re: 400 external flexplate [Re: Purphaz] #725384
06/16/10 07:45 AM
06/16/10 07:45 AM
an8sec70cuda Offline
I'd be looking for a new transmission repair man that is actually familiar with Mopars.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 400 external flexplate [Re: an8sec70cuda] #725385
06/16/10 09:04 AM
06/16/10 09:04 AM
Northeastern, Pa
P
Purphaz Offline OP
Purphaz  Offline OP
P
Northeastern, Pa
He knows what piece we need. His supplier is at fault. We've been trying to locate the correct part. I thought I'd ask around here to see what people have available. Thanks for sharing that information 70AARcuda.
Re: 400 external flexplate [Re: Purphaz] #725386
06/16/10 02:50 PM
06/16/10 02:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I'm curious, why would the supplier recommend "redrilling" the flexplate? Are the bolt holes off or is the bolt circle incorrect?
Re: 400 external flexplate [Re: John_Kunkel] #725387
06/16/10 11:30 PM
06/16/10 11:30 PM
Northeastern, Pa
P
Purphaz Offline OP
Purphaz  Offline OP
P
Northeastern, Pa
They said this in response to the bolt holes being off. We have since located the correct part and it has solved the problem. Thanks for the help.
Re: 400 external flexplate [Re: Purphaz] #725388
06/17/10 12:24 PM
06/17/10 12:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That's interesting, what did you get ? The FLEXPLATE is just that, a flexplate and it's NEUTRAL balance, what you said he told you to get above does not exist, there are not wide ring gear weighted plates from the factory , the gear for the starter is on the convertor .
Re: 400 external flexplate [Re: Purphaz] #725389
06/17/10 11:01 PM
06/17/10 11:01 PM
Dude has a wire crossed!
You either need the external balanced flexplate that B&M makes (large pie cut out of one side of it) that uses a NEUTRAL balance torque convertor
OR
You need a torque convertor with the external balance weights attached.
