400 external flexplate
#725382
06/15/10 09:19 PM
06/15/10 09:19 PM
Posts: 66 Northeastern, Pa
Purphaz
Northeastern, Pa
Hello. I'm in a state of confusion. I'm looking for any sources on how I can obtain a correct flex plate for my 400 in my 74 Road Runner. The engine has a year "76" casting. The transmission is a Torqueflight. The terrible vibration the car has, has let to a faulty 360 flex plate that someone drilled to make it work for the 400. The gentleman performing the transmission repair informed me that I need a wide ring gear, 2 weight, offset bolt pattern flex plate that will fit a 10 3/4 - 11 in torque converter. This gentleman has requested such a flex plate twice and has received the wrong bolt pattern. The piece is for a 360. The supplier instructed him to simply re-drill and adapt to the 400, however, that is already the case. I appreciate all your help.
Re: 400 external flexplate
[Re: Purphaz]
#725383
06/15/10 09:30 PM
06/15/10 09:30 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
look at b&m 10237
Chrysler '71 & later externally balanced 383, 400, 440 with cast crank and A-727 (These special Chrysler Flexplates must be used when changing converters on an externally balanced engine.)
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Purphaz]
#725384
06/16/10 07:45 AM
06/16/10 07:45 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I'd be looking for a new transmission repair man that is actually familiar with Mopars.
[Re: Purphaz]
#725386
06/16/10 02:50 PM
06/16/10 02:50 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I'm curious, why would the supplier recommend "redrilling" the flexplate? Are the bolt holes off or is the bolt circle incorrect?
[Re: John_Kunkel]
#725387
06/16/10 11:30 PM
06/16/10 11:30 PM
Purphaz
Northeastern, Pa
They said this in response to the bolt holes being off. We have since located the correct part and it has solved the problem. Thanks for the help.
[Re: Purphaz]
#725388
06/17/10 12:24 PM
06/17/10 12:24 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
That's interesting, what did you get ? The FLEXPLATE is just that, a flexplate and it's NEUTRAL balance, what you said he told you to get above does not exist, there are not wide ring gear weighted plates from the factory , the gear for the starter is on the convertor .
[Re: Purphaz]
#725389
06/17/10 11:01 PM
06/17/10 11:01 PM
Dude has a wire crossed!
You either need the external balanced flexplate that B&M makes (large pie cut out of one side of it) that uses a NEUTRAL balance torque convertor
OR
You need a torque convertor with the external balance weights attached.
