who pushes and who pulls auto. shifters.
#724288
06/14/10 03:45 PM
06/14/10 03:45 PM
i'm thinkin' about changing to pushing instead of pulling my trans. shift lever. goin' from a turbo action pulling shifter to a PPP pushing forward shifter. is pushing better than pulling. also looks like i'll be going transbrake style. what's your poison? push or pull?
Re: who pushes and who pulls auto. shifters.
[Re: dOc !]
#724298
06/14/10 06:49 PM
06/14/10 06:49 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I beeez a PUSHER ..... I loves me BUTTONS !!
Dooster,you know me,,,,,Ahhz be a pusher too
[Re: viperrt]
#724299
06/14/10 07:05 PM
06/14/10 07:05 PM
Posts: 2,051 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Pull back 2nd to 3rd for the burnout. Then the air cylinder takes over during the run.
Mine too! B & M Pro Ratchet w/ home made air shifter.
Brian Dunnigan
#724300
06/14/10 07:46 PM
06/14/10 07:46 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Puller, was a pusher.
I wrote PULL on a piece of tape and stuck it on my dash...Kinda like my Motocross days when I ran two classes, one on a bike that braked on the left, shifted on the right, one braked on the right and shifted on the left...Or was it the other way around....?
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#724301
06/14/10 08:03 PM
06/14/10 08:03 PM
Pusher I took my TurboAction shifter and changed it from a cable out the front to a cable out the back . I like the TA shifter because I can get any length cable from a local boat shop.
[Re: JACKSON]
#724303
06/14/10 08:52 PM
06/14/10 08:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
yo dooster, with a pusher,i think it would be harder to push than pull,especially when you get slammed back in the seat,also those are transbrake VB's. push button to go in reverse.
My TA transbrake (non low band apply) doesnt require a button... just put it in reverse like normal... this is a reverse pattern VB and shifter
[Re: MR_P_BODY]
#724304
06/14/10 09:02 PM
06/14/10 09:02 PM
Mr.P forgot to mention, i want the free nuetral shifter after 3rd going through the stripe. so i'm wondering if pushing might be the better way to go. ppp sells either style. just wondering if after all these years, gpoing from pulling to pushing might mess me up.
#724305
06/14/10 09:10 PM
06/14/10 09:10 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I like to pull for 2 reasons 1 the g-force deal 2 I like to pull the shifter away from N but seeing you are going for a clean N VB you will be going towards N regardless
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
#724306
06/14/10 09:14 PM
06/14/10 09:14 PM
hemi-itis
Stick with the puller
