too much cam????? kinda long-please help!!!!!
#723406
06/13/10 09:27 PM
06/13/10 09:27 PM
Posts: 281 las vegas
70challenger408
las vegas
need some opinions guys. During the winter, I lost 2 cam lobes on my racer brown hydraulic cam(242@.050 543 int/510 ex). decided to rebuild with a solid roller cam this time. I called COMP CAMS, and they sold me grind 20-740-9(248/254@050, 616 int/582 ex 110 LSA. I also changed the intake to a victor 340, and had the dynamic converter reworked to 4200 stall(was 3800). long story short, took it to the track, and lost 1 full second. best with old motor was 12.7 @105mph. so, have been told too much cam is the fault. sorry, car is 1970 challenger, 3800# 408Ci, oob indybrock heads, 10.7cr, 727 and 3.55 rear gears. help me oput here guys. ![](/ubbthreads/images/graemlins/bawling.gif)
Re: too much cam????? kinda long-please help!!!!!
[Re: 70challenger408]
#723407
06/13/10 09:31 PM
06/13/10 09:31 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
you have to start with the basic..
was the cam degreed? advanced?
timing set correctly?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
#723408
06/13/10 09:34 PM
06/13/10 09:34 PM
Posts: 2,177 ill
dennismopar73
ill
i had to reread that 2 x full sec?? hard to believe racer brown really good stuff thats not the total reason has to be something going on not enough info say fuel related best guess right now ![](/ubbthreads/images/graemlins/shruggy.gif)
#723410
06/13/10 09:39 PM
06/13/10 09:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Its not really that big... but with the gear you have it might be a touch slow reving... give us the whole low down on your engine... do your heads have any port work done on them... need info... also like was asked.. did you degree it ![](/ubbthreads/images/graemlins/wave.gif)
[Re: forphorty]
#723412
06/13/10 09:41 PM
06/13/10 09:41 PM
Posts: 2,177 ill
dennismopar73
ill
[Re: S/ST 3040]
#723418
06/13/10 09:59 PM
06/13/10 09:59 PM
Posts: 2,177 ill
dennismopar73
ill
unless it was retarded bad those wouldn t do it unless they were all bad??@@ something hes not telling ![](/ubbthreads/images/graemlins/whistling.gif)
#723419
06/13/10 10:01 PM
06/13/10 10:01 PM
Posts: 2,177 ill
dennismopar73
ill
there ya go ![](/ubbthreads/images/graemlins/popcrn.gif) now theres some really good info mmmm my first was ? ? ![](/ubbthreads/images/graemlins/panic.gif)
#723420
06/13/10 10:01 PM
06/13/10 10:01 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
1st problem really need to degree the cam. The cam that is in my motor right now when I put it in strait up and then checked it with a degree wheel it was off 6 degrees.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
#723423
06/13/10 10:09 PM
06/13/10 10:09 PM
MR_P_BODY
ok mr p-body, the engine is a 408 10.7:1CR heads are oob IndyBrock(reworked like TA heads with pushrods moved over) no porting done. has 1.6 roller rockers on intake, and 1.5 exhaust. intake is a port matched victor 340 topped with BG 750 mighty demon. ignition is a MSD 6a firing a stock distibutor(recurved by don gould at 4secondsflat.com. Initial timing at 20deg advance, with 34 total at 3000rpm. still have stock jetting in carb. fuelpump is a holley hp150 billet pump. I think the pump may be a problem(flow tested after the regulator, an d found 31 secounds to pump 2 gallons.) ohh-cam was not degee'd-did not have the means at the time-installed strait up. did notice that the plugs were white, and the color on the ground strap started close to the threads---too lean?????
Ok next ... give us the time slip numbers(all of them) need to find out where its bad at.... you didnt degree it in so that could be a MAJOR problem... you really dont know where its at... and its lean from what you said.... you have plenty of supply with the 2 gal at 31 sec... also did you flash the converter or is that the number it was suppose to be... if your cam is way off you wont make the torque to work the converter ![](/ubbthreads/images/graemlins/wave.gif)
[Re: dennismopar73]
#723424
06/13/10 10:11 PM
06/13/10 10:11 PM
MR_P_BODY
straight up will run!! wont kill a full sec
Straight up dont mean nothing... what happens if the dots are off... is it still straight up.... NOT ![](/ubbthreads/images/graemlins/wave.gif)
#723425
06/13/10 10:15 PM
06/13/10 10:15 PM
Posts: 2,177 ill
dennismopar73
ill
with the combo i see a little tinkering i think you could very well see 11 sec car there?? but i see you drive it alot?? so the 355 is a great gear i ran 391 for years on the street, i wasnt trying to be rude so looks like you have this in hand have a ![](/ubbthreads/images/graemlins/2231195-dggif.gif)
