Page 1 of 3 1 2 3
too much cam????? kinda long-please help!!!!! #723406
06/13/10 09:27 PM
06/13/10 09:27 PM
las vegas
70challenger408 Offline OP
las vegas
need some opinions guys. During the winter, I lost 2 cam lobes on my racer brown hydraulic cam(242@.050 543 int/510 ex). decided to rebuild with a solid roller cam this time. I called COMP CAMS, and they sold me grind 20-740-9(248/254@050, 616 int/582 ex 110 LSA. I also changed the intake to a victor 340, and had the dynamic converter reworked to 4200 stall(was 3800). long story short, took it to the track, and lost 1 full second. best with old motor was 12.7 @105mph. so, have been told too much cam is the fault. sorry, car is 1970 challenger, 3800#
408Ci, oob indybrock heads, 10.7cr, 727 and 3.55 rear gears. help me oput here guys.
Re: too much cam????? kinda long-please help!!!!! [Re: 70challenger408] #723407
06/13/10 09:31 PM
06/13/10 09:31 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
you have to start with the basic..
was the cam degreed? advanced?
timing set correctly?
Tony
70 AARCuda Vitamin C
Re: too much cam????? kinda long-please help!!!!! [Re: 70challenger408] #723408
06/13/10 09:34 PM
06/13/10 09:34 PM
ill
dennismopar73 Offline
ill
i had to reread that 2 x
full sec??
hard to believe
racer brown really good stuff
thats not the total reason has to be
something going on
not enough info
say fuel related best guess right now
Re: too much cam????? kinda long-please help!!!!! [Re: 70challenger408] #723409
06/13/10 09:39 PM
06/13/10 09:39 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
What ever the old intake was, put it back on and eliminate that as a variable.
Re: too much cam????? kinda long-please help!!!!! [Re: 70challenger408] #723410
06/13/10 09:39 PM
06/13/10 09:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its not really that big... but with the gear you have
it might be a touch slow reving... give us the whole
low down on your engine... do your heads have any port
work done on them... need info... also like was asked..
did you degree it
Re: too much cam????? kinda long-please help!!!!! [Re: dennismopar73] #723411
06/13/10 09:41 PM
06/13/10 09:41 PM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
How many passes with the new set-up? It might take awhile to get timing, jetting and shift points worked out.
Re: too much cam????? kinda long-please help!!!!! [Re: forphorty] #723412
06/13/10 09:41 PM
06/13/10 09:41 PM
ill
ill
NOT THE INTAKE
Re: too much cam????? kinda long-please help!!!!! [Re: bobby66] #723413
06/13/10 09:43 PM
06/13/10 09:43 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
I would start with the gears....3.55's???
Re: too much cam????? kinda long-please help!!!!! [Re: MR_P_BODY] #723414
06/13/10 09:45 PM
06/13/10 09:45 PM
ill
ill
unless it retarted bad cant see a full sec
sure he didnt put the bad cam back in?? hahah
Re: too much cam????? kinda long-please help!!!!! [Re: MIKES_DUSTER] #723415
06/13/10 09:48 PM
06/13/10 09:48 PM
ill
ill
NOT THE GEARS
comon guys
he has not given enough info to make even a good guess
Re: too much cam????? kinda long-please help!!!!! [Re: dennismopar73] #723416
06/13/10 09:56 PM
06/13/10 09:56 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Let's see............
The intake, camshaft and converter was changed. What could it be?
Re: too much cam????? kinda long-please help!!!!! [Re: MR_P_BODY] #723417
06/13/10 09:58 PM
06/13/10 09:58 PM
las vegas
las vegas
ok mr p-body, the engine is a 408 10.7:1CR
heads are oob IndyBrock(reworked like TA heads with pushrods moved over) no porting done. has 1.6 roller rockers on intake, and 1.5 exhaust. intake is a port matched victor 340 topped with BG 750 mighty demon. ignition is a MSD 6a firing a stock distibutor(recurved by don gould at 4secondsflat.com. Initial timing at 20deg advance, with 34 total at 3000rpm. still have stock jetting in carb. fuelpump is a holley hp150 billet pump. I think the pump may be a problem(flow tested after the regulator, an d found 31 secounds to pump 2 gallons.) ohh-cam was not degee'd-did not have the means at the time-installed strait up. did notice that the plugs were white, and the color on the ground strap started close to the threads---too lean?????
Re: too much cam????? kinda long-please help!!!!! [Re: S/ST 3040] #723418
06/13/10 09:59 PM
06/13/10 09:59 PM
ill
ill
unless it was retarded bad
those wouldn t do it
unless they were all bad??@@
something hes not telling
Re: too much cam????? kinda long-please help!!!!! [Re: 70challenger408] #723419
06/13/10 10:01 PM
06/13/10 10:01 PM
ill
ill
there ya go
now theres some really good info
mmmm my first was ? ?
Re: too much cam????? kinda long-please help!!!!! [Re: 70challenger408] #723420
06/13/10 10:01 PM
06/13/10 10:01 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
1st problem really need to degree the cam.
The cam that is in my motor right now when I put it in strait up and then checked it with a degree wheel it was off 6 degrees.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: too much cam????? kinda long-please help!!!!! [Re: MIKES_DUSTER] #723421
06/13/10 10:02 PM
06/13/10 10:02 PM
las vegas
las vegas
was running 3.91's, but I drive it to the track, and the rpm's were up there. I changed to the 3.55's, and getting to the track was easier, and my 1/4 times did not suffer. woul,d a change in gears help too big a cam????? come on guys, I am learning here, if I wanted to take crap, I would talk to the wife!!!!!!!
Re: too much cam????? kinda long-please help!!!!! [Re: dusturbd340W5] #723422
06/13/10 10:07 PM
06/13/10 10:07 PM
ill
ill
straight up will run!!
wont kill a full sec
Re: too much cam????? kinda long-please help!!!!! [Re: 70challenger408] #723423
06/13/10 10:09 PM
06/13/10 10:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ok next ... give us the time slip numbers(all of them)
need to find out where its bad at.... you didnt degree
it in so that could be a MAJOR problem... you really
dont know where its at... and its lean from what you
said.... you have plenty of supply with the 2 gal
at 31 sec... also did you flash the converter or is
that the number it was suppose to be... if your cam
is way off you wont make the torque to work the
converter
Re: too much cam????? kinda long-please help!!!!! [Re: dennismopar73] #723424
06/13/10 10:11 PM
06/13/10 10:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Straight up dont mean nothing... what happens if the
dots are off... is it still straight up.... NOT
Re: too much cam????? kinda long-please help!!!!! [Re: 70challenger408] #723425
06/13/10 10:15 PM
06/13/10 10:15 PM
ill
ill
with the combo i see
a little tinkering i think you could very well see 11 sec car there??
but i see you drive it alot??
so the 355 is a great gear
i ran 391 for years on the street,
i wasnt trying to be rude
so looks like you have this in hand
have a
Page 1 of 3 1 2 3
