Finally got the parts...now need a question answered #722521
06/12/10 05:41 PM
06/12/10 05:41 PM
Sweet Home, Oregon
friesza Offline OP
friesza  Offline OP
Sweet Home, Oregon
I got lucky and found 2 Darts in the wrecking yard...both with 10" drums and of course with bigger spindle and ball joint...got all for $100..all of it except lower control arms... question is...do I need the lower control arms ..I thought I read somewhere you don't need them..just the uppers? I am converting to a scarebird disk setup. . I have been thinking of buying the other setup off the other car too.
Re: Finally got the parts...now need a question answered [Re: friesza] #722522
06/12/10 05:44 PM
06/12/10 05:44 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I think the lowers are the same on a disk or drum car. If they are factory sway bar equipped lower arms then grab them for sure.
Re: Finally got the parts...now need a question answered [Re: Neil] #722523
06/12/10 05:47 PM
06/12/10 05:47 PM
Sweet Home, Oregon
friesza Offline OP
friesza  Offline OP
Sweet Home, Oregon
Actually what I was wondering is...are the 72's the same ball joint as the 73's?
Re: Finally got the parts...now need a question answered [Re: Neil] #722524
06/12/10 05:50 PM
06/12/10 05:50 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Lower control arms are the same for drum brake, or disc brake cars.
No difference.
Same thing for the uppers, wether it is drum, or disc brake.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Finally got the parts...now need a question answered [Re: friesza] #722525
06/12/10 05:52 PM
06/12/10 05:52 PM
hemi71x Offline
hemi71x  Offline
72's and earlier are small ball joint uppers, and 73-76 are the large ones.
Re: Finally got the parts...now need a question answered [Re: hemi71x] #722526
06/12/10 05:53 PM
06/12/10 05:53 PM
Sweet Home, Oregon
friesza Offline OP
friesza  Offline OP
Sweet Home, Oregon
Sorry I am scatterbrained today... I mean the Lower ball joints....
Re: Finally got the parts...now need a question answered [Re: friesza] #722527
06/12/10 05:57 PM
06/12/10 05:57 PM
hemi71x Offline
hemi71x  Offline
Ok, here we go again.
72 and earlier lower ball joints use two different ones.
One for drum brake cars, and one for disc brake cars.
The 73-76 cars use the same ball joint no matter if the car is drum brake, or disc brake.
Re: Finally got the parts...now need a question answered [Re: hemi71x] #722528
06/12/10 08:21 PM
06/12/10 08:21 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
THIS subject again?
Mr Hemi71x thinks that NO 73-76 A body EVER came with the small upper ball joint from the factory. He may be right, but I have personally seen a few of them over the past 14 years of junkyard digging. Cars with the 9 inch front drums used the small upper ball joint, no matter what year model. My point I tried to make a few weeks ago was that while some stubborn, crusty egomaniacs will quote.." I have NEVER I repeat NEVER ever seen the 9 inch front drum on ANY 73 and later A body...." Dont believe it. Just because YOU have never seen it does not mean it never happened. Sure, the odds may be against it, but unless you worked the assembly plant, you are only an observer.
Another option to consider is that since these cars have been on the road so long, they have likely had multiple owners. There are few virgins anymore. I once had a 76 Dart that had 9 inch drum brakes all around, as did a 74 Dart Sport. It is possible that at some time in the past that a previous owner went metal to metal and couldnt find a 10 inch drum for a replacement. THEN he found a complete 9 inch setup INCLUDING the corresponding upper control arms and swapped them all over. Wierder things have happened. These cars have alot of interchangeability in them.
Re: Finally got the parts...now need a question answered [Re: Kern Dog] #722529
06/12/10 11:43 PM
06/12/10 11:43 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Re: Finally got the parts...now need a question answered [Re: Kern Dog] #722530
06/13/10 01:03 AM
06/13/10 01:03 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I bought a late Valiant 4dr at an auction once for the disc brakes. When I went to pull it apart I found it had the 4-piston small pattern system. It was a '73 or '74, can't remember which. It looked all factory except for the discs, the rear axle was a big pattern 7.25" and it still had the factory tiny exhaust system on the 225 but had torsion bars over 1" in diameter! I still have the torsion bars, they appear to be machined out of 1-1/4" hex bar and are real nice pieces.
Just because you see it on a car doesn't mean it's factory.
Re: Finally got the parts...now need a question answered [Re: @#$%&*!] #722531
06/13/10 01:53 AM
06/13/10 01:53 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Many people have played mix and match with these cars..... So Belvedere jim... you think that everyone that disagrees with you is crazy? Grow up.
Re: Finally got the parts...now need a question answered [Re: Kern Dog] #722532
06/13/10 03:33 AM
06/13/10 03:33 AM
I was switching an early A body (forgot if it was 63-66 group or 67-72) and the only diff between the disc and the drum lower ball joints was on the drum ones the mounting holes were 1/2" dia and were 9/16" on the disc ones. there was plenty of material around the bosses so I drilled them out (to 9/16") which took seconds on a drill press as the cast iron was as soft as butter. No problems & saved an unnecessary expenditure.
Re: Finally got the parts...now need a question answered [Re: RapidRobert] #722533
06/13/10 03:47 PM
06/13/10 03:47 PM
Sweet Home, Oregon
friesza Offline OP
friesza  Offline OP
Sweet Home, Oregon
I guess I have not made myself clear....I know 73 up have large ball joints....but ...are the lower control arms the same from 72? as in a 73?... I just need to know if I need to get them too..they do not have the tabs for a sway bar...I thought I read somewhere that I did not need to get them...I searched and could not find any correlating messages...I am sorry if some here are tired of hearing these questions asked..but this is my favorite board and really the only place I ask questions and would not ask if I did not need help. and these are from a drum brake car...not disk...
Re: Finally got the parts...now need a question answered [Re: friesza] #722534
06/13/10 03:52 PM
06/13/10 03:52 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
No , you do not need the lower control arms , they are the same if they do not have swaybar tabs but are different if they do have swaybar tabs and you need to have the correct swaybar to go with the arms , you will have to get the correct lower ball joints to fit the spindles you want to use .
Re: Finally got the parts...now need a question answered [Re: friesza] #722535
06/14/10 02:08 AM
06/14/10 02:08 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I have parted out several A body cars as well as pulling parts from wrecking yards. All of the lower control arms seem to physically fit from 64-76. The designs will look different in a few cases, and YES sway bar tabs complicate things. STILL... the dimensions are the same as far as I have found.
Re: Finally got the parts...now need a question answered [Re: Kern Dog] #722536
06/14/10 04:40 AM
06/14/10 04:40 AM
Sweet Home, Oregon
friesza Offline OP
friesza  Offline OP
Sweet Home, Oregon
Thanks...the last two answers were all I need to know....
