Camber/Caster gauge recomendations #721576
06/11/10 04:13 PM
06/11/10 04:13 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
I'm looking for a wheel mounted caster/camber gauge that will work a variety of wheel sizes and types.
I have been measuring camber by just trig'ing out a bubble level measurement and pretty much winging the caster measurement.
I'm not looking for anything fancy and want to keep the cost down but I do want to be able to measure a true camber and caster number. Any suggestions?
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Camber/Caster gauge recomendations [Re: CJK440] #721577
06/11/10 04:35 PM
06/11/10 04:35 PM
Yep
The old magnetic kind ( I have a cave era Snap On ) do great! The best buys are on the circle track sites and magazines--modern units are really very affordable--I bet used are $100 range new $300
Herb McCandless used one to do my race car and hundreds of others--I use "slick" magazines as turn tables when I do one--and even the turn tables are at auctions ALL the time--old garages etc and are pretty cheap on Ebay Once you get used to using one you can do a car in no time and they are very accurate--usually you just pull the grease cap off the drum or rotor and you are ready to go--I made a flat steel plate and even did my Neon roadrace car with ease--with one of those and a string you can build and line up most anything no matter what folks say. Good luck!
Re: Camber/Caster gauge recomendations [Re: ] #721578
06/11/10 05:15 PM
06/11/10 05:15 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: Camber/Caster gauge recomendations [Re: CJK440] #721579
06/11/10 05:32 PM
06/11/10 05:32 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
