Can you re-hone an unused "fresh" hone? #720483
06/10/10 11:24 AM
06/10/10 11:24 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I know this is going to sound stoopid, but can you re-hone an unused "fresh" hone? As in, if the bore & hone work done by the "old" shop who machined my 448 short block doesn't compare favorably to the work being done to my 452 block by a "new" shop, would it be feasible to have the "new" shop re-do the other place's hone before I bother assembling the engine?
Yeah, I know... I'm
Re: Can you re-hone an unused "fresh" hone? [Re: BradH] #720484
06/10/10 11:27 AM
06/10/10 11:27 AM
Why not have it redone to the conditions you like?Hopefully it will only take less than .002 to .003 out ofthe bores It would be just like having a race motor rehoned after 60 to 100 runs, that is done all the time. Most motors I know of run better on the 2nd rering hone
Re: Can you re-hone an unused "fresh" hone? [Re: BradH] #720485
06/10/10 11:46 AM
06/10/10 11:46 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I hope so!
Re: Can you re-hone an unused "fresh" hone? [Re: BradH] #720486
06/10/10 01:10 PM
06/10/10 01:10 PM
NC
440Jim Offline
440Jim  Offline
NC
IMO,
The plus would be a better cylinder surface finish, hopefully for better ring seal/life. The negative would be a looser resulting piston to bore clearance; assuming it was correct after the first hone.
If it changes 0.0005" or 0.0020" just depends.
Re: Can you re-hone an unused "fresh" hone? [Re: 440Jim] #720487
06/10/10 02:07 PM
06/10/10 02:07 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Just make sure whoever rehones does it right.
My 383 for my stroker was rehoned , not sure when it was screwed up, 1st time or the 2nd time , but the cylinders are hourglass shaped now and have to go to the next overbore to clean up ... good thing I have a spare block already machined
Re: Can you re-hone an unused "fresh" hone? [Re: JohnRR] #720488
06/10/10 02:13 PM
06/10/10 02:13 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Typically no. It has hone grooves in it that holds the oil up there, now you rehone it, and its got even more grooves. Depending on the angles and such, I can't see how you attain proper oil control with two different sets of grooves. Not to mention piston to wall clearance gets worse.
Re: Can you re-hone an unused "fresh" hone? [Re: BradH] #720489
06/10/10 02:50 PM
06/10/10 02:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah, I know... I'm
Its a new hone job... run it
Re: Can you re-hone an unused "fresh" hone? [Re: Dragula] #720490
06/10/10 02:54 PM
06/10/10 02:54 PM
S/ST 3040 Offline
S/ST 3040  Offline
I honed mine by hand with a 320 grit Flex-hone strictly for finish.
Change in bore size was practically immeasurable with .0001" bore gauge.
Re: Can you re-hone an unused "fresh" hone? [Re: S/ST 3040] #720491
06/10/10 03:56 PM
06/10/10 03:56 PM
UK
602heavy Offline
602heavy  Offline
UK
Yep , have to be on it all day & some to remove any material from cylinder wall when using a dingle berry (flex hone), these give a real good finish depending how fast you spin the drill along with how quick you pull it in & out , gotta get a real fine balance with these.
Re: Can you re-hone an unused "fresh" hone? [Re: S/ST 3040] #720492
06/10/10 04:04 PM
06/10/10 04:04 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I hope so!
Damn S/ST ... that looks NICE ...but a little coarse ...
You using CHROME rings ?...
Re: Can you re-hone an unused "fresh" hone? [Re: dOc !] #720493
06/10/10 06:15 PM
06/10/10 06:15 PM
I hope so!
i think that's to test to see how long the plasma moly will stay on the rings...
Brad, do you have pictures of the hone job you want redone?
what exactly is wrong with it?
Re: Can you re-hone an unused "fresh" hone? [Re: S/ST 3040] #720494
06/10/10 07:53 PM
06/10/10 07:53 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
too rough
Re: Can you re-hone an unused "fresh" hone? #720495
06/10/10 08:29 PM
06/10/10 08:29 PM
BradH Offline OP
BradH  Offline OP
I'll have to dig up the ol' digi-cam.
Uhhhh... probably nothing... other than it's mine and I'm second-guessing the work done because of a couple of other things about the block that have me thinking "" about how much to trust the work.
Re: Can you re-hone an unused "fresh" hone? [Re: cbarracuda] #720496
06/10/10 08:46 PM
06/10/10 08:46 PM
S/ST 3040 Offline
S/ST 3040  Offline
too rough
13.5 lbs. to turn over with cam, timing set w/tensioner.
.043"/.043"/3mm rings
