Front Spring Hanger same on 71, 72 B-body as 73, 74 #718562
06/07/10 09:35 PM
06/07/10 09:35 PM
Baltimore, MD
3
397STROKER Offline OP
super street
super street
3
Baltimore, MD
Is the front spring hanger on a 71, 72 B-body the same as the one used on a 73, 74 B-body?
Re: Front Spring Hanger same on 71, 72 B-body as 73, 74 [Re: 397STROKER] #718563
06/08/10 09:05 PM
06/08/10 09:05 PM
Baltimore, MD
3
super street
super street
3
Baltimore, MD
Nobody?
Re: Front Spring Hanger same on 71, 72 B-body as 73, 74 [Re: 397STROKER] #718564
06/09/10 12:07 AM
06/09/10 12:07 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
74 is the exception... they used a smaller bolt to fit a thicker isolator on front bushing, so the hole is smaller.
however the fitment on body is exactly the same in all 71/74
Re: Front Spring Hanger same on 71, 72 B-body as 73, 74 [Re: NachoRT74] #718565
06/09/10 01:00 PM
06/09/10 01:00 PM
Baltimore, MD
3
super street
super street
3
Baltimore, MD
Thnaks. Didn't 74 go to the oval shaped spring eye?
Re: Front Spring Hanger same on 71, 72 B-body as 73, 74 [Re: 397STROKER] #718566
06/09/10 06:00 PM
06/09/10 06:00 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
well, not in my case or several I have seen. Ovals are Station wagons and maybe sedans too I think
then also C bodies
if you get a 74 bracket you simply can enlarge the hole to fit on earliers, and will be done. Backwards will be moslty sure harder to do.
I will be needing a 74 bracket pretty soon BTW.
Re: Front Spring Hanger same on 71, 72 B-body as 73, 74 [Re: NachoRT74] #718567
06/10/10 12:24 AM
06/10/10 12:24 AM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
Every 74 I've seen has had the oval spring eye, of about (6) 74 parts cars.
The oval break more than others and many have been changed to the round type.. Sometimes one side only....
Re: Front Spring Hanger same on 71, 72 B-body as 73, 74 [Re: Mr_fixit] #718568
06/10/10 01:02 AM
06/10/10 01:02 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
well not in my case... who knows why. ( beside mine was assemblied in Venezuela, not in USA )
whatever is the reason, go for the sure side and get 71/73s
