1969 440 fuel pump line ?? #714238
06/02/10 03:00 PM
06/02/10 03:00 PM
New Berlin,Wi
Firepowerflyer Offline OP
New Berlin,Wi
I'm working on a 69 GTX the feed fuel line that runs along the unibody looks like 3/8 but the pump looks to be 5/16.I know the orginal pump had a threaded fitting,this aftermarket one just has the nipples on it.Whats a guy to do??
Thanks Joe
Re: 1969 440 fuel pump line ?? [Re: Firepowerflyer] #714239
06/02/10 03:02 PM
06/02/10 03:02 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Should be 3/8" in & 5/16" out....
1MYTGTX
Re: 1969 440 fuel pump line ?? [Re: 1MYTGTX] #714240
06/02/10 03:12 PM
06/02/10 03:12 PM
New Berlin,Wi
New Berlin,Wi
Who sells that correct fuel filter?Also my pump does not look like that one.
Re: 1969 440 fuel pump line ?? [Re: Firepowerflyer] #714241
06/02/10 03:54 PM
06/02/10 03:54 PM
New Berlin,Wi
New Berlin,Wi
Ok I think I have the wrong pump I found the correct one at napa should have it Friday to check it out.
Re: 1969 440 fuel pump line ?? [Re: Firepowerflyer] #714242
06/02/10 04:35 PM
06/02/10 04:35 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Not necessarily a fuel filter but a vapor seperator that has a screen in it.....make sure your car also has the 1/4" return line....
Bill Allphin has them
www.amhightechauto.com
1MYTGTX
Re: 1969 440 fuel pump line ?? [Re: 1MYTGTX] #714243
06/02/10 04:50 PM
06/02/10 04:50 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
ps- 1969 440 cars SHOULD be a 5/16" main line and fuel pump inlet + outlet, BUT with a 3/8" sender at the tank and with a 1/4" return line.
3/8" main lines in 1969 SHOULD be Hemi only.
I've owned 4 1969 GTX's and none were 3/8" main line.
again, I'm not saying all were 5/16" main as I know of a few that are supposed original 440 cars with 3/8" main lines
Re: 1969 440 fuel pump line ?? [Re: gtx6970] #714244
06/02/10 06:46 PM
06/02/10 06:46 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
My 69 GTX and 69 R/T both 4 speed cars if it matters had 3/8 lines. The R/T had the original lines in it till I touched it.
Also your fuel pump should look like this:
Re: 1969 440 fuel pump line ?? [Re: 1MYTGTX] #714245
06/02/10 06:56 PM
06/02/10 06:56 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The pump shown in the above photo is not Resto correct for a 440, depending on the pt# it may be correct for a Hemi... That said it is a better design pump than the correct piece & is what I prefer to run..
The pump in this photo is correct but the teflon tape is not...
Re: 1969 440 fuel pump line ?? [Re: 1_WILD_RT] #714246
06/02/10 07:31 PM
06/02/10 07:31 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
RJS's pump looks the same as yours just painted? The fuel pumps were painted on the engine...but maybe not quite as nicely as his. His spring clip for the vapor return line is correct except I've seen them in black. I agree with Bill that 1969 440-4 and 440-6 all came with 5/16" lines. However, there is nothing wrong with going to the 3/8" Hemi line on a
440...and swearing it's OE.
Re: 1969 440 fuel pump line ?? [Re: RoadRunnerJD] #714247
06/02/10 07:41 PM
06/02/10 07:41 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
RJS posted while I was working on my post & got side tracked.. My comment about a hemi style pump was refering to the post by 6T9_CHARGER_RT ... And painted is correct... Also I agree about the 5/16 vs 3/8 fuel line...
Re: 1969 440 fuel pump line ?? [Re: RoadRunnerJD] #714248
06/02/10 07:51 PM
06/02/10 07:51 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
My 69 Charger R/T had 3/8" lines as well
I should have elaborated about the Hemi Carter pump though...sorry bout that
1MYTGTX
Re: 1969 440 fuel pump line ?? [Re: 1MYTGTX] #714249
06/02/10 08:12 PM
06/02/10 08:12 PM
New Berlin,Wi
New Berlin,Wi
Me again,I'm not 100% positive if the car had 3/8 from the factory,I thought it did,but I'm not positive.I replaced them with a set from fine lines,so it is 3/8 right now.I did a search on here and got the correct part number for a carter pump with the threaded end that will work with the 3/8 line.So did all the cars have the vapor canister?
Thanks for the replys
Joe
Re: 1969 440 fuel pump line ?? [Re: Firepowerflyer] #714250
06/02/10 09:05 PM
06/02/10 09:05 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
1969 440 and Hemi cars had 3/8" lines. I believe the confusion is when we speak 69 440-6 cars because they started life as 383 cars and got 5/16" lines.
Re: 1969 440 fuel pump line ?? [Re: RJS] #714251
06/02/10 10:30 PM
06/02/10 10:30 PM
Warrenton, VA
Warrenton, VA
1969 440 cars were designed to have 5/16" fuel lines and 1/4" vapor return for original equipment. Any that came through with 3/8" were a mistake and do not meet the OE specifications. Unless you are the original owner of an unrestored car, you can't assume that it is original. Even if you have 440 cars or heard (this is called heresay) of others with 3/8" lines, based on the input you are getting here, I would not draw a conclusion that all 440's came with 3/8" lines. 5/16" is correct for 440's...honest!
Re: 1969 440 fuel pump line ?? [Re: RoadRunnerJD] #714252
06/03/10 10:57 AM
06/03/10 10:57 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
I owned and stripped out/junked quite a few 440 cars back in the day and all I had were 5/16" main line.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
