lifters 273/340 #713413
06/01/10 05:38 PM
06/01/10 05:38 PM
louisville,kentucky
moparmangolf Offline OP
louisville,kentucky
will the 273 solid lifters,pushrods,and rockers that you can ajust work in a 340, with a 500 lift solid cam ?
Re: lifters 273/340 [Re: moparmangolf] #713414
06/01/10 05:48 PM
06/01/10 05:48 PM
scratchnfotraction Offline
yes
Re: lifters 273/340 [Re: scratchnfotraction] #713415
06/01/10 09:08 PM
06/01/10 09:08 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Yep, that is what I used in my 340 with the MP 284/.528" cam with dual springs.
Floyd Lippencott IV
Re: lifters 273/340 [Re: moparmangolf] #713416
06/01/10 09:09 PM
06/01/10 09:09 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Usually it is OK but you need to make sure if they are the bar-bell lifters they do not go too far down in the lifter bore and allow the oil to flow directly out of the bottom of the bore. A lot of aftermarket cams have smaller base circles and add to that core shift and you can have a major internal oil leak.
If they are the solid body lifters than there is no problem
Re: lifters 273/340 [Re: HotRodDave] #713417
06/02/10 09:52 AM
06/02/10 09:52 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
273 rocker arms used a bolt that is held in position by friction. I had to buy the new ones with a lock nut.
Re: lifters 273/340 [Re: babarracuda] #713418
06/02/10 08:54 PM
06/02/10 08:54 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
They had an interference fit on the threads. Mine were still tight, but I hear a lot of them were worn from adjusting them. You would have to retap and spot face for the nut. I'm not sure if the adjuster or the rocker had the oddball thread.
Floyd Lippencott IV
