which cam for most hp & tq #710802
05/29/10 01:22 PM
05/29/10 01:22 PM
windsor, onatrio canada
metcoll Offline OP
metcoll  Offline OP
all things being equal on a 440 which cam would make more power old 509 or lunati 240/250 520/547 cam.....
Re: which cam for most hp & tq [Re: metcoll] #710803
05/29/10 11:43 PM
05/29/10 11:43 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
The M/P cam, I believe. Since its' intro, there
has been two versions of it with the differences
limited to the centerline. 108 vs. 114.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: which cam for most hp & tq [Re: metcoll] #710804
05/30/10 12:26 AM
05/30/10 12:26 AM
Az
Crizila Offline
Crizila  Offline
Az
If the rest of your combo ( heads,intake,carb ) is based on 25+ year old technology, go with the 509 - of course, advanced 4+ degrees
Fastest 300
Re: which cam for most hp & tq [Re: metcoll] #710805
05/30/10 02:07 AM
05/30/10 02:07 AM
Desert Tracker
Desert Tracker
Now if you want to turn up the wick a little,
running 440ez/Eddy/MP Stage 5's or "other"
bolt on aluminum heads, with a bigger carb/intake
and headers, I would look at the Lunati or bigger
juice sticks from Hughes or Comp Cams. If you are
a horsepower junkie who runs the streets, a good
small solid or roller with good lift will do well
too. Food for
Re: which cam for most hp & tq [Re: HYPER8oSoNic] #710806
05/30/10 11:51 AM
05/30/10 11:51 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Ran them both in RB 440's and in a 451 low deck, that Lunati will walk the dog on the old 509....take it to the bank. In the 1/8th mile I ran a 6.96 @ ~96 mph in a 3200 lb 73 duster w 3.91 gear on McCreary dirt track tires with a 3500 stall fairbanks, Self ported 452 Iron heads 10.7:1 shortblock with 6.36" rods, M1 and a tweaked 830 Nascar carb....The lunati was about equal to a 509 up to 3500 but much stronger above 4500, worked best in my motor at 104ICL (hit the vert harder and I had to go up in tire size to get her to hook. I ran the pro-parts headers and the flowmaster pulse techs phased 180, (which picked it up over a tenth in the 1/8th once I jetted up) that was one nasty sounding motor, really unique sound for the pre 'X-pipe" days.
509 is no slouch but that lunati was one of those grinds that they really got right for the old wedge. I sold that cam to a guy in California that put it in his 440 tunnel ram "pleasure" boat
I wound up de-tuning the duster to the old single pattern 230/230 .515 Hughes (engle) once they shut the local track down, that was a really snappy daily driver.
WIZE
In Car:
