Re: Did 71 B Bodies come with H pipes on six pack cars
[Re: Tom Swope]
#709014
05/27/10 11:17 AM
05/27/10 11:17 AM
Posts: 5,268 NY
70440+6bbl
NY
Yes they did (on some). I will see if I can dig up an older post on this board and the Roadrunner Nest where it was discussed in length. There was a change over later in the year where the factory started to use seperate headpipes. I owned a '71 U-code GTX that still had it's original H-pipe with the factory flattened areas. It had a SPD of Dec 17th 1970. A few other members have survivor cars that still have the OEM H-pipes. We compared our Broadcast sheets and the cars with H-pipes listed this in the front pipe boxes: EXHAUST LT RT 00 01 The cars equipped with regular headpipes had: EXHAUST LT RT 93 76
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5 ‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7 ‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
[Re: 70440+6bbl]
#709018
05/27/10 11:48 AM
05/27/10 11:48 AM
Posts: 5,268 NY
70440+6bbl
NY
[Re: 70440+6bbl]
#709019
05/27/10 12:03 PM
05/27/10 12:03 PM
Posts: 1,053 Ont, Canada
gygeneral
Ont, Canada
Great information. Looks like I posted on the original Moparts discussion but I guess I didn't follow up or my memory isn't what it used to be. No comments please My car's spd is 523 so looks like no H pipe for me. Many thanks
[Re: gygeneral]
#709020
05/27/10 12:58 PM
05/27/10 12:58 PM
Posts: 7,906 Lower AZ
AZ-Nick
Here Since 1996!
Here Since 1996!
Lower AZ
Here is a picture of my 71 GTX with original exhaust and you can see the H pipe.. SPD 924
71 GTX 4sp Dana GY9
HD Road King
[Re: AZ-Nick]
#709021
05/27/10 01:12 PM
05/27/10 01:12 PM
AZ-Nick
Here Since 1996!
Here Since 1996!
Lower AZ
H pipe part number for 1971 was 346646 and 3466994-5
While it does say 426, it was also installed on 440 some motors. Here is a picture of the parts book sheet
71 GTX 4sp Dana GY9
HD Road King
[Re: rayztoy]
#709024
05/27/10 03:04 PM
05/27/10 03:04 PM
AZ-Nick
Here Since 1996!
Here Since 1996!
Lower AZ
that is why it is so upsetting to read the many posts on Moparts that the person posting is told.... "He is wrong" "He doesn't know what he is talking about" "I have never seen a car like that so none were ever made" "Until you show me proof I will not believe you" This is all Bull, there were so many variations back then and unless you pulled the parts and assembled the car yourself, you only have an assumption based on a BS or FT.... Granted there are some really knowledgeable people here on Moparts that have accumulated many years of pictures and documentations and have seen and examined many cars out there, they have findings that are worthy but not 100% accurate, really, unless they were there back then, bets are all off..... I will give you an example: I bought a 71 GTX from the original owner, he ordered the X and waited for it to be delivered. He has owned it all this time until I purchased it. When I purchased it we spent time talking about the car and and the history of what he did with it and the problems he had with it. He even kept the original factory installed tires and rims he removed when he installed the slotted mags on the X back in 71. When I bought the car he surprised me be putting them back on the car for me. Well the X is a 4sp so the carb listed for it should be 4967S, well it isn't, it is a 4968S, this is an Auto carb. I have been called an idiot and I do not know what I am talking about by a so called expert here on Moparts, he said no way that carb was installed on your car, show me the documentation that it was installed..... Bullsh-it, to you and to all that think that way..... I better stop and turn the rant off, step off the soapbox and have a cup of coffee..
71 GTX 4sp Dana GY9
HD Road King
[Re: Snoopy]
#709027
05/27/10 08:58 PM
05/27/10 08:58 PM
gygeneral
Ont, Canada
From the 70-71 Factory Parts Book. Jan 72 revision.
w/440 Eng. 70 - 3404802 w/440 Eng. 71 - 3466994 & 3466995
It would be nice if someone had an earlier version of the parts book which could confirm what the conclusion is, that earlier up to Jan 71 it was an H pipe with only one part number then to the two part numbers mentioned above.
