Re: B Body Column Shifter Help
[Re: A4SixtyNineRR]
#707893
05/26/10 01:03 AM
05/26/10 01:03 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
There's a roll pin that pushes out and should pull right out then.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: moparsquid]
#707895
05/26/10 01:18 AM
05/26/10 01:18 AM
Silver70
Rust Belt, SW PA
its very simple pop the roll pin at the box take of the linkage 3or4 bolts on the fire wall 2 under the dash diconect the harness and pull, verry easy and I think the paddock or year one has new shifter knobs.
I think he just wants to pull the actual shifter handle, not the entire column.
[Re: Silver70]
#707897
05/26/10 03:29 AM
05/26/10 03:29 AM
Posts: 90 Columbus, Ohio
A4SixtyNineRR
Columbus, Ohio
I already have the column out and the wheel off, but I wasn't sure what all was involved in pulling off the rusted shifter handle. Thanks for the input so far. By the way, the rumor is that Paddock is out of business. It says they are currently closed when you call no matter what time of day and the website has said they are doing an update for the last week or more so it seems the rumor might actually be true??
