NO BUS 98 RAM #707347
05/25/10 02:25 PM
05/25/10 02:25 PM
OHIO
BUBBAZ572 Offline OP
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
I HAVE A NO BUS CODE THAT IS DISPLAYED WHERE THE MILEAGE NUMBERS ARE.
ANY BODY KNOW WHAT THIS IS? AND HOW TO FIX IT?
98 RAM 2500 V10 ENGINE, AUTOMATIC TRANS,2WD
Re: NO BUS 98 RAM [Re: BUBBAZ572] #707348
05/25/10 02:34 PM
05/25/10 02:34 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Do you get "nothing" when you turn the key?
Re: NO BUS 98 RAM [Re: Fat_Mike] #707349
05/25/10 02:48 PM
05/25/10 02:48 PM
OHIO
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
ALL I GET IS NO BUS.
AND NONE OF THE GAUGES WORK.
THE ENGINE RUNS OK
Re: NO BUS 98 RAM [Re: BUBBAZ572] #707350
05/25/10 02:59 PM
05/25/10 02:59 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
THE ENGINE RUNS OK
I've experienced this on a Jeep and it was a loose connection on the plug that attaches to the guage cluster.
Re: NO BUS 98 RAM [Re: BUBBAZ572] #707351
05/25/10 03:01 PM
05/25/10 03:01 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
OK, this is going to be very non-technical.
My buddy's 01 Ram with a 5.9 had the same code, but the engine wouldn't turn, etc when he turned the key. After alot of frustrating trial and error, here's what did the trick (again, very non-technical):
To the rear of the battery there's an electrical/fuse box. When you pop the plastic cover, there should be a main wiring harness that is held down by a screw. Although we didn't disconnect the battery, it may be wise to do so. Anyway, loosen the hold-down screw, pull the harness, clean the pins (if necessary), and plug it all back together. His code went away and he's had no further issues since performing those simple steps (seems as if is was simply a bad connection there somewhere). Perhaps someone with real knowledge will chime in. Good luck with it!!!
Re: NO BUS 98 RAM [Re: BUBBAZ572] #707352
05/25/10 04:32 PM
05/25/10 04:32 PM
Columbus Ga
reflections7 Offline
Columbus Ga
Computers bad. Got a new one on ebay for a real good price sent them the info and they programmed it and all. Plug and play for 300 or so. 360 magnum durango.
Re: NO BUS 98 RAM [Re: reflections7] #707353
05/25/10 09:01 PM
05/25/10 09:01 PM
Arizona
Chucklehead Offline
Chucklehead  Offline
Arizona
On my 99 Ran that happened a few times I just smacked the dash and it would work again. I took the instrument cluster out and checked the connections, no problems since. Oddly enough it happen on hot days and not cold days. I figured heat expansion was causing a poor connection?
Still Broke
Re: NO BUS 98 RAM [Re: reflections7] #707354
05/27/10 12:16 AM
05/27/10 12:16 AM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
Very possible. But checking wire harness connections is a lot cheaper, as in free.
