Drive Shaft Yoke
#70464
06/09/08 03:07 PM
06/09/08 03:07 PM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
Will the yoke on the driveshaft from an auto transmission work in a manual transmission? Reason asking is because I have an auto drive shaft that I was trying to put in my 4 speed and it seems that the yoke is too small and it won't fit over the splines on the output shaft in the trans. I thought the yokes were the same.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Drive Shaft Yoke
[Re: Skeez]
#70467
06/09/08 10:41 PM
06/09/08 10:41 PM
73cuda340
clarks summit pa
Yoke was from a 904 tranny. I have a 727 drive shaft out of a challenger; will this work? I know the challenger is 2 inches longer overall.
[Re: 73cuda340]
#70468
06/09/08 11:44 PM
06/09/08 11:44 PM
Posts: 75,128 A Banana Republic near you.
JohnRR
you can use the yoke but not the driveshaft . if the u joint sizes are the same swap the yoke .
[Re: sthemi]
#70470
06/10/08 08:55 AM
06/10/08 08:55 AM
JohnRR
there is a conversion joint to cross over the two different size joints and would allow the big yoke to fit the small shaft. But, I think the 727 yoke is two inches longer than the 904 so you are back to no good.
the length of the yoke isn't an issue , the shaft for the chally is a different length than the cuda because the wheelbase is different.
unless of course the length difference is forward of the trans mount ???
[Re: JohnRR]
#70471
06/12/08 03:21 PM
06/12/08 03:21 PM
73cuda340
clarks summit pa
I tried the challenger driveshaft and as expected it was about 2 inches longer. The yoke was correct though.
[Re: 73cuda340]
#70472
06/12/08 04:59 PM
06/12/08 04:59 PM
JohnRR
just think the time you wasted on that you could have swapped the yoke onto the other shaft ???
[Re: 73cuda340]
#70474
06/13/08 10:42 AM
06/13/08 10:42 AM
JohnRR
The other shaft that I have is too long also. I just had this shaft already and figured it was worth a try.
i just went back and looked at this again , it appears you have the driveshaft from a car with a 904 originally , i sort of missed that. the driveshaft for a 904 is longer than a 727 by more than the challenger 727 driveshaft is due to the wheelbase difference .
you need to get a measurement and get one of those shafts shortened and rebalnced , assuming they are worthy of the operation , ie: not a crusty mess ...
![](/ubbthreads/images/graemlins/sawzall-smiley.gif)
